Mechwarrior 2 Decomp/Recomp
Reply 100 of 112, by Mikeyy00
myne wrote on 2026-11-14, 14:58:
Didn't get into the game yet. Mercs +Titanium files. Something seems screwy with mech customisation. Pretty sure even the shit […]
Something seems screwy with mech customisation. Pretty sure even the shit box commando can go to 9 armor on the head.
Mouse is a bit floaty
F keys mostly don't work as usual. F5 I think it was, did. The rest didn't.
cannot read bwd id 1490
Sorry, is this Mercs acting busted?
Reply 101 of 112, by KHORG
I've just fired up the MW2 recomp, some things I've noticed when comparing it to the DOS 1.1 version which I have running through dosbox:
  • The grey MW2 menu cursor seems to have been replaced with a default windows cursor?
  • If you click on the Archive Holoprojector, it cuts to a zoomed-in view of the "projection" animation, then cuts back again to the normal view. Usually it just runs this animation in the distance of the hall, then cuts to the display.
  • There's some kind of slim vertical red line on enemy target brackets when selecting enemies.
  • Using Z to zoom in immediately causes the 3D cockpit outline to be culled by the renderer. It only re-appears when you shift-zoom all the way back to default.
  • Funnily CTRL-Z has carried over the buggy behaviour from the original game. It was meant to reset your zoom, but in original MW2 had a bad tendency to bounce the camera around.
  • The Satellite View doesn't show a top-down view of your own mech, it also incorrectly carries over enemy targetting brackets from first-person view and puts them in random places.
  • The floatiness of the original targetting reticle seems to be gone. Now if you let go of a key it immediately stops.
  • There's a big frame-rate drop when turning on or off light amplification. Image enhancement is fine.
  • The turrets on wolf level 2 don't seem to be able to turn. They just start blazing away in whatever direction they were originally pointing at.
  • There are various 3D hill objects missing from wolf mission 2. They should be visible as soon as you drop in.
  • When you arrive at a Nav point, two things should happen; 1) the unselected nav icon on your radar for that location should dim slightly (this works) 2) the text for "Nav Alpha" in the bottom left of the screen should also dim (and stay dimmed even if you change to a different waypoint then back) to indicate you've already been there, this doesn't occur.
  • Satellite View doesn't show enemy buildings in red outline (particularly on Wolf 3), it just shows them as black outline.
  • Satellite View also doesn't show the enemy fire in yellow. Usually you can see incoming PPCs, lasers and missiles.
  • On your targetting MFD, (bottom left display) the helicopter on wolf mission 3 should show as a blue fuselage and a red circle for the blade above it, but only the fuselage appears in the MFD view.
  • The NPC vehicle (automobile) driving around on wolf 3 isn't there.
  • On wolf mission 3, the red or green roof-lights on the taller building aren't there. Usually they should fade in and out, being either green or red.
  • In Satellite View, 2D sprites like fires should appear as little fire images, but currently they only show as a black line.
  • In original or recomp MW2, when you're shooting the ground, there is a black puff of dust. However in the original game there is a semi-bug when shooting buildings, static vehicles etc. In this case it should show a weapon splash effect, but it didn't always, sometimes the angle on the building/object would be wrong and you would instead see a black puff of dust and wonder if you were hitting it. However, in the recomp it only shows the black puff of dush when shooting buildings/objects, not the weapon splashes.
  • F5-F6-F7-F8 should act as alternates for the right MFD, e.g. if you press F8, you can press F5 to cycle back to the default mode. This doesn't work in the recomp, instead.... F5 and F6 are linked to each other, F7 and F8 are also linked, you need to press F8 again before you can get back to F5 and all sorts of UXUI that makes my head hurt.
  • If you look down (CTRL up/down) in the Mad Dog cockpit, you can see the backs of the Mad Dog legs, which you shouldn't be able to. I haven't checked all the other mechs for this.
  • Wolf Trial 1, the first two mechs don't move until you're looking down on them from a hill, they should be moving towards you at about the 10 second mark (which is a couple of seconds after you're fully online).
  • Wolf Trial 1 again, the second two mechs should start moving towards you as soon as you destroy the Engagement Sphere. Instead the first only moves towards you when attacked, and his starmate follows him around like an AI with no attack orders.
  • Some of the original 'flight sim' controls seem to have changed? In the original game, UP aimed down and CTRL-UP looked down. In the recomp, UP aims down and CTRL-DOWN (not CTRL-UP) looks down.
  • Sable Flame is all kinds of busted. The Sensor Array Dome is opaque when it should be transparent and you should be able to see into it and through it.
  • Also on Sable Flame, the 2nd Mech group should power up after you destroy the 1st, and the 3rd should power up after you destroy the 2nd. But the the 2nd and 3rd come online at the same time after the 1st is destroyed. Also weirdly the 1st group doesn't appear on radar after betty announces Enemy Powerup Detected.
  • Still on Sable Flame, the third group of mechs get distracted by a Wolf dropship which is flying around above them and instead run around shooting at that.
  • Still on Sable Flame, the Falcon dropships have a Wolf logo on the side (I checked in the original, it's definitely the Falcon logo there).
  • Dropships seem not to be able to turn/aim their turret on top, so like the current problem with static turrets, they just shoot straight forwards when they see something.
  • Still on Sable Flame, there is some weird switcheroo going on with which mechs are in which group, it should be 3-2-3. But instead it's 2-2-4? One of the Mad Dog's from the first star ends up in the last and I feel like the Stormcrow changed group also.
That said, various niche functionality does work, e.g. Ammo dumping is fine, as is Autopilot. The dusk effect that kicks in at the start of Wolf 3 is identical to the original game.
I'll have a further look. It would be nice to be able to get it to optionally use cd audio, rather than ripped tracks.
Reply 102 of 112, by myne
Mikeyy00 wrote on 2026-11-14, 19:23:
Yes.
First mission : training patrol failed to load with cannot read bwd is 1490
I built:
Reply 103 of 112, by Deffnator
i found another visual bug with the navcam when using satellite link, it is the same i reported earlier
The attachment 16730847756444237824_20261113130226_1.png is no longer available
Reply 104 of 112, by Mikeyy00
KHORG wrote on 2026-11-15, 02:50:
I've just fired up the MW2 recomp, some things I've noticed when comparing it to the DOS 1.1 version which I have running throug […]
Wicked feedback. Thank you. I'll see if I can bang a bunch of these out.
100% I can bring back OG CD Audio support.
Reply 105 of 112, by Mikeyy00
Deffnator wrote on 2026-11-15, 12:32:
I'll tackle this after the laundry list above.
Reply 106 of 112, by Mikeyy00
myne wrote on 2026-11-15, 03:02:
Yes.
Try the build just posted, let me know if that solves the issue.(v.1.2.3)
Reply 107 of 112, by Mikeyy00
Mikeyy00 wrote on Yesterday, 01:24:
Most of these are fixed in 1.1.24.. CD audio can be played from BIN/CUE now too. I'll have physical disc CD audio on the next build.
Reply 108 of 112, by KHORG
Mikeyy00 wrote on Yesterday, 02:59:
Thrown into Claude and fixed, or something else? I downloaded 1.1.24 and had a look in the first 3 wolf missions, but all 14 of the bugs I checked were still there.
A couple of the above bugs might need screenshots from me to better show what should be occurring. But halfway through it was starting to feel like my actual work, so I got lazy.
Reply 109 of 112, by KHORG
On 1.1.24
  • Changing from Standard to Endo-Steel in the mechlab gives you extra criticals to assign, but doesn't free up weight.
  • Burning Chrome has gained some kind of strange 3D object, it's like a disassembled dropship (but your dropship, the enemy dropship and the solar array are all there and intact). You can walk through it and shoot through it.
  • Four of the turrets on Burning Chrome have changed position, I think one of them might be outside the icewall (e.g. outside the normal mission boundary).
  • My mech got shot up on Burning Chrome and 3 lasers were destroyed, so turned black in the weapon-selection. One turned red though, as though it had just been fired. It was destroyed, and couldn't be selected. I feel like this was an occasional bug in the original game also.
Reply 110 of 112, by Mikeyy00
KHORG wrote on Yesterday, 10:54:
On 1.1.24 […]
On 1.1.24
These are fixed in 1.1.26.
Yes, firing stuff into Claude. I did give it shit though for not re-evaluating all of the missions for similar bugs, its doing another pass now.
While I'd like to pretend I know programming to look at the code, I don't. So, yeah I need to fire it into an LLM to fix.
I really appriciate the feedback on bugs though, you've clearly played the crap out of it to catch so many. I'll keep prodding it to fix what it can.
Edit, it's done it's pass. 1.1.27 is up.
Also, it can only verify the port against the DOS version. There's no easy way for the LLM to run Titanium so it can't like for like there. vs. DOS where it spins up a Dosbox instance to compare the port against. (gist is, expect more bugs when using Titanium).
Reply 111 of 112, by gerwin
I just did a search and there is competition on the horizon.
https://combatace.com/forums/topic/101646-gam … -classic-games/
Not to discourage you. But no harm in being realistic.
Personally, I will eventually pick a project that does a 100% DOS binary matching as a side repo, and an enhanced ported repo next to it. If that luxury exist. I predict it soon will, for DOS things in general.
Reply 112 of 112, by Deffnator
gerwin wrote on Yesterday, 17:43:
I just did a search and there is competition on the horizon. https://combatace.com/forums/topic/101646-gam … -classic-games/ No […]
I want Strike Eagle III and Fleet Defender, id kill for both as mainly 1942 TAW Gold
