Reply 80 of 92, by robertmo3
i uploaded it again as previous was not from a cold boot
robertmo3 wrote on 2026-11-15, 01:13:i uploaded it again as previous was not from a cold boot
Fantastic. It's still very early, but it's working. Screenshots below. I have one on order myself.
I didn't realize there was this much interest in this but it should be much simpler than PowerVR to finish.
sento and creep clash work too.
you can move the sword with tab.
check the .ini file in game if game has access to all the folders
and check my pm
Thanks, got it. I'm going to want to get a physical card to continue the project, even though it seems to be working fairly good already. Hopefully arriving this week.
Code is here for now, it's very rough but will hopefully work better soon. The VLB card works better in emulation so far, and it needs a BIOS to work in the video/matrox folder of roms: https://github.com/z2k-retro/86Box/tree/mga-impression-plus
@ubertrout
Incredibly cool. Thank you very much.
Great to see Icehawk working again.
Here are the files from PowerVR PCX1 Card.
I used Slackware 14.2 running on my Pentium 180Mhz MMX, Apocalypse 3D PCX1 and Diamond Viper TNT1 PCI.
The third test, hangs the machine.
matze79 wrote on 2026-11-16, 20:57:Here are the files from PowerVR PCX1 Card.
Thanks, the dumps were really useful. They’re written up in Appendix I of the tools repo, including that the fog and divider tables are RAM on the PCX1 and that IEEEFP, BILINEAR and FASTFOG don’t exist.
If you’re willing to try one more run: the texture test now does the driver’s full start-up sequence first, which is the likely difference from what hung last time. Please update and rebuild, then run only the texture test:
cd powervr-pcx2-tools && git pull && makesudo bin/pcx2dump --texmem
Type yes at the prompt. It may still hang the machine. It can’t harm the card, and everything up to that point is saved to disk first. Either way, please send the new pcx2dump-… folder. Even after a hang, its report.txt will show whether the tables loaded correctly.
Here you go!
matze79 wrote on Yesterday, 19:49:Here you go!
Thanks for running it again! Unfortunately the texture test was skipped both times: the tool only continues if you type the whole word yes at the warning. Could you try once more? This version skips the question, so there’s nothing to type:
cd powervr-pcx2-tools && git pull && makesudo bin/pcx2dump --texmem --yes
The first line of the new report should begin with pcx2dump 292225e or a later version. It may hang the machine again. That’s fine, since the report is saved first. Please send the folder either way.
hi buddy @ubertrout thanks for this, amazing
i too am a (previous) PCX2 owner...have built a working Vulkan shader version of the chip including the usual enhancements, AA, ansio, texture packs -would this be something to also incorporate from a speed / upscaling PoV?
please see attached for more info
and yes, of course, credit where it's due could not have done it without Opus 5.5...
ubertrout wrote on Today, 03:55:Thanks for running it again! Unfortunately the texture test was skipped both times: the tool only continues if you type the whol […]
cd powervr-pcx2-tools && git pull && makesudo bin/pcx2dump --texmem --yesThe first line of the new report should begin with pcx2dump 292225e or a later version. It may hang the machine again. That’s fine, since the report is saved first. Please send the folder either way.
Ah, Sorry.
Seems the keyboard language was switched and i tipped zes or so
i will run it again soon.
fla56 wrote on Today, 12:52:hi buddy @ubertrout thanks for this, amazing […]
Glad you enjoyed and cool to see this being built on! I didn't run into too many speed issues with the wrapper I made (also with Opus) but making real 3d acceleration work with it sounds even better and opens more doors!
