Exploring the performance of the Matrox G550
Reply 100 of 114, by vvbee
The question of hardware T&L is resurrected. The answer is, the G550 does appear to have functional hardware T&L for DX7 and DX8 (not OpenGL), starting sometime around driver 6.7x. It can be exposed in 6.83 by changing g550dd32.dll's bytes 0xeac1 (DX7) and 0x59f11 (DX8) from 74 to eb.
The attachment g550hwtnl.gif is no longer available
Based on brief testing, it appears to work generally speaking, but some types of polygons have issues. Game 1 in 3DMark2000 for example has glitched terrain while game 2 renders with few to no glitches. On a P4 2.4 GHz test machine hardware T&L loses a bunch of performance, around 50% in 3DMark2000. In Evolva hardware T&L gets around 27 FPS while software T&L hits the vsync limit at 60. I don't know whether this T&L would be of use on a slower CPU, maybe.
Even though hardware T&L isn't exposed by default, apparently fog is always computed by the on-board T&L engine, unlike on the G400 which doesn't appear to have any. Says Claude's analysis.
Reply 101 of 114, by The Serpent Rider
Doesn't seem to be right, unless applied to OpenGL.
Reply 102 of 114, by vvbee
It seems very right since that's what the driver appears to get up to. If you can show otherwise then please do.
Reply 103 of 114, by The Serpent Rider
It straight up ignores software T&L D3D option?
Reply 104 of 114, by vvbee
There's no T&L pre-DX7 so yes. But also there's no specific DX option to compute fog by the driver on the CPU that I'm aware of. I'm talking about table fog by the way.
Reply 105 of 114, by dr.zeissler
If you are comparing G400 to G450 / G550 these things came to my mind.
- Older Games benefit more from the 128Bit memory interface of the G400 than the DDR-Ram of the later cards (450/550) with 64Bit interface
- G450 does support EMBM in Expendable by RAGE, G550 does not work.
- G450/550 both lack VSYNC in OpenGL mode that is essentiel for lot's of the remakes of classic intro's and cracktros of the 16Bit area (Atari/Amiga)
- G450 has a working Win3x driver for WinOS/2 but no native Win3x driver itself. Don't know if the G550 works too. G400 should have a native Win3x driver.
The second texture-unit of the G550 does not benefit that much in real performance. In short the G550 is mostly only 20-30% faster, but perhaps this depends on the game (engine).
Doc
Reply 106 of 114, by vvbee
Claude wrote a microcode fix for the card's hardware T&L glitch that came up for example in 3DMark2000's terrain. Very cool. Fairly involved too, I think near zero chance this would ever have been fixed by hand.
The attachment 3dm2kcmcf.jpg is no longer available
I can still see an occasional issue, but starting to look like proper full hw T&L on this card. Needs to be tested on a slow CPU though to see what the actual value is.
Reply 107 of 114, by vvbee
dr.zeissler wrote on 2026-11-17, 08:16:
If you are comparing G400 to G450 / G550 these things came to my mind. […]
Doc
1: I've seen this claim but not evidence for it.
2: The G550 supports EMBM when using analog output.
3: Both should have vsync control in OpenGL. On: "User3D.SwapIntervalExtFlags"=dword:00000001, "User3D.SwapIntervalExtEnable"=dword:00000000. Off: "User3D.SwapIntervalExtFlags"=dword:00000009, "User3D.SwapIntervalExtEnable"=dword:00000000. Under HKEY_LOCAL_MACHINE\SOFTWARE\Matrox\PowerDesk\Current Settings.
4: No idea.
The G550 benefits considerably when games use multitexturing; it's 40% faster than the G400 in Thief for example. By comparison the G400 MAX is something like 15% faster than the G400 generally speaking, and this is the frame the G550 sits in.
Reply 108 of 114, by dr.zeissler
2. Perhaps a software issue in expendable? Have you tried it. It does not work with G550, with G450 everything is fine.
3. Might also be software (engine) related, but it did not work for me.
Reply 109 of 114, by vvbee
Vsync works for me in the Quakes. EMBM works on my G550. By default the G550 doesn't filter bumpmaps, with driver 6.83 change g550dd32.dll's byte 0x124b0 from 00 to ff. Maybe Matrox had a good reason to do this and maybe not.
The attachment ebrmbe.jpg is no longer available
Reply 110 of 114, by dr.zeissler
Please try:
https://cyberpingui.pages-perso.free.fr/realpcremakes.htm
direct link https://cyberpingui.pages-perso.free.fr/dl.php?id=714
Maybe it's just "engine related". I have to check it again. I have to lookup the machine and the driver I was using.
In my case neither G450 AGP or G550AGP had working VSYNC in openGL with the demo scene-remakes that use OpenGL.
But the tearing was not that bad.
Reply 111 of 114, by vvbee
Run one of the Quake games instead. If it works then you did it correctly and you have the answer. Don't say it doesn't work without testing it though. I used driver 6.83.
The hardware T&L unit on the G550 is apparently a MIPS processor, so you can run arbitrary code on it. I had Claude write a plasma fire effect and patch it in, and yes, it appears to run on the thing. Claude's estimate based on the FPS and the amount of data and whatever was around 120 MHz, so maybe it's running at the speed of the core at 133 MHz or so.
Reply 112 of 114, by Putas
Amazing times we live in. Can Claude or similar tools give more insight into the WARP engine as well?
Reply 113 of 114, by Ozzuneoj
vvbee wrote on 2026-11-17, 16:42:
Wow, that's very cool. I know this is a whole different issue, but it makes me wonder if there's a way to create a workaround for the broken T&L on the S3 Savage 2000.
Reply 114 of 114, by fosterwj03
Doc
The G550 (to include the PCIe version) works in OS/2 with the driver meant for the G450. No idea why Matrox didn't bother doing the same for Windows 3.x and NT 3.51.
