Reply 360 of 373, by zami555
mwdmeyer wrote on 2026-08-15, 03:37:
if you can run the dos exe I can collect info about your card and try and build a supported driver
Nice to see your great work. I'm impressed with what you'd like to achieve and crossing my fingers for success.
I believe so far nobody attached some results from survey tool so please find atached the results from my computer. It's the VLB card with S3 Trio64V+ chip (86C765) designed by Madao.
The mainboard in my computer is a bit uncommon as it uses EDRAM. There could be something suspicious in results as I'm experiencing issues with this card in Windows 3.11. None of the drivers dedicated for this S3 chip works there. Just plain VGA 3.0 driver works. In contrast in DOS everything works without any issue. (some details can be found here: Re: S3 ViRGE VLB project (or " Making a Concurrent for Creative 3D Blaster VLB" ))
Reply 361 of 373, by Oerg866
I do have a VIRGE VLB card (prometheus) but without any hardware changes, running on TRIO64V+ VBIOS, so it's likely useless. But if I get the time I can do some tests for you
Reply 363 of 373, by mkarcher
mwdmeyer wrote on 2026-08-22, 11:41:
Do you know for the MMIO issue if you wrote a driver (and if so MMIO at A0000 is itself broken over VLB) or attempted to work a […]
Do you know for the MMIO issue if you wrote a driver (and if so MMIO at A0000 is itself broken over VLB) or attempted to work around with the existing Virge PCI MMIO driver?
Trio style MMIO puts its acceleration registers into one of two memory ranges CR53 bit 5:
A: the registers appear at 0xA0000–0xAFFFF (the 64 KiB segment normally used for VGA graphics memory).
B: the registers appear at 0xB8000–0xBFFFF (the text-mode segment, 32 KiB).
It does not matter what mode you use. I can't disclose any details, but the issue occurs when you mix access to framebuffer memory and certain regions of the MMIO space. One possible consequence ist corruption of the hardware configuration. The worst case is accidentally enabling bus interface features like PCI retries while the chip is in VL mode, which will lock up the VL bus at some time later. The PCI interface of the ViRGE does not have the same issue: The troublesome access patterns are handled perfectly by a PCI-connected ViRGE. As the issue only appears when you mix framebuffer and MMIO access, you won't observe it if you use variant A without having the LFB enabled, because there would be no way to access the framebuffer at all. On the other hand, variant B (the "Trio 64 new MMIO") allows a 64KB windows of the frambuffer at A000 while MMIO is at B800, which is susceptible to this problem even without using the LFB at some high memory address.
As the ViRGE/DX is quite closely related to the classic ViRGE, I wouldn't be surprised if the core still contains the same buggy VL interface, but it has just been shut down by S3 to prevent it from being used. I actually modded a PCI ViRGE/DX card to strap the chip like you would strap a classic ViRGE for VL, and the ViRGE/DX stayed in PCI mode, and reading the configuration strap register clearly showed that one of the two strap resistors for the bus interface configuration is not picked up by the ViRGE/DX.
Reply 364 of 373, by RayeR
BTW how did you do the VL mod and read back config register? Did you do it on a regular PCI card just by modding strap resistors? I would expect if the chip will switch to VLB mode then you couldn't communicate with it anymore via PCI and it just lock up the PC...
And couldn't be the MMIO range protected some way by memory manager - VMM and let only permission to driver to access it?
Reply 365 of 373, by mkarcher
RayeR wrote on 2026-09-21, 13:40:
Exactly. I just modded strap resistors on the PCI card. There are two straps for the bus type, and Trio64V+/ViRGE just document "01" for VL and "10" for PCI. The ViRGE/DX kept responding as PCI device no matter how the straps were set, and the low one was always reading back as zero. So I got "00" or "10" as readback with a perfectly working PCI interface, although "00" is not specified to work.
Yeah, you can protect the MMIO range permitting only the driver to access it. But the issues I had were due to the driver mixing MMIO stuff (accessing the accelerator) and framebuffer access (unacelerated drawing in case acceleration makes no sense).
Reply 366 of 373, by mwdmeyer
zami555 wrote on 2026-08-28, 18:56:
Nice to see your great work. I'm impressed with what you'd like to achieve and crossing my fingers for success. I believe so fa […]
Thanks, helpful information from the survey. I will send you another version once ready. If your EDRAM chipset doesn't decode 0x62000000 that will probably explain the issue you are having. I'll let you know!
Reply 367 of 373, by mwdmeyer
mkarcher wrote on 2026-09-20, 17:32:
Thank you, this is very useful information and makes pretty clear how difficult (or not possible) it would be to solve. I'm focusing on getting hardware Direct3D Intel GMA950 working in Windows 98 at the moment, so will have more of a think about it later.
In the meantime I've logged these in the repo for future review
https://github.com/michaeldale/velocity9x/blo … vlb-old-mmio.md
https://github.com/michaeldale/velocity9x/blo … uffer-mixing.md
Reply 368 of 373, by onethirdxcubed
If the problem is having the MMIO and the framebuffer ever mapped at the same time, what if you didn't map them at the same time and switched the configuration back and forth using the page fault handler?
Reply 369 of 373, by RayeR
Yes, same idea, if driver could actively switch between MMIO and LFB as needed (enable MMIO only when calling some accelerated functions. But I guess it would be big performance penalty if switching needed too often...
Reply 371 of 373, by RayeR
I can see that in last commit it gets support for intel GMA9xx. The direction moves to more modern GPUs, so it could open another dimmension for W9x. One of important missing thing is some driver for relative modern NV/AMD/intel GPUs at least with some basic 2D accel that could be better than VBEMP. How hard would be with AI assistance e.g. to port some basic function of linux nouveau opensource nvidia driver? Also the same would be nice for NT4, just dreaming... 😀
Reply 372 of 373, by mwdmeyer
Very possible, that is what I am doing. NT/2000/XP is basically another driver, which I will move to in future.
I have this tool for Windows 98 that allows AI to drive the machine remotely, take screenshots, load drivers etc https://github.com/michaeldale/V9x-Remote-Agent
Jump into this thread Velocity9x - Open Source Win9x VGA 3D Driver S3/Intel/ATi/Matrox/NVIDIA/SiS and I can help more.
Reply 373 of 373, by Madao
A little notice.
S3D toolkit 2.6 use only newMMIO schema -> not for Virge VLB ..
