The king of operating systems and compatibility
Reply 20 of 33, by DarthSun
dr_st wrote on Yesterday, 16:18:
No internal optical drive = trash, send it to the landfill 😆 […]
DarthSun wrote on 2026-11-17, 20:59:
LG external BDRW (Blu-ray writer) drive
DOS 6.22
DOS 7.1
Win98 SE
You installed 3 DOS versions when you only need one (Win98 SE which includes DOS 7.1). I wonder - why does everyone keep doing that?
Win11 22H2 – considering an update to 25H2/26H2
Wait, so you are running the modern version of Windows, but an outdated and unpatched build of it? Why? Win10 22H2 I can understand, but Win11 22H2 is out of support and doesn't even get security patches anymore.
Intermediate operating systems would certainly run as well, but they are no longer practical for my needs, so I have omitted them for logical reasons.
On that we agree.
Just kidding. 😉 Do what you want, and don't let people talk you down. Every build is fun. 👍
Thanks for the encouragement.225621_c0k0mr6vwupunfyi_smiley_png63.png 225621_nebjo0vs4pisokhf_smiley_png67.png
Yeah, DOS: Win98 on the internal SSD, 6.22 on a flash drive, and a 7.1 version accessible via a menu on an external SSD... because you just need it. 225621_x0pqux3q4mfxprh0_av-6835.png
Actually, I could manage the update to 26H2 using an MBR bootloader—anything is possible these days... I’ll give it some thought.
As for the optical drive: it’s a modern case—I need it for the dedicated vertical PCI slot—but this one no longer has any internal 5.25-inch bays.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 21 of 33, by Dothan Burger
DarthSun wrote:
*Monkey Island*, *Ultima VII*, or *Falcon*—these aren’t really my cup of tea, but I’ll give them a try.
Monkey island runs just fine in windows 98 with a system like this. As for Ultima and Falcon I personally don’t know or care if they run as I’ve never heard of them.
Reply 22 of 33, by jh80
Never heard of Ultima? That's quite a surprise.
Reply 23 of 33, by pete8475
DarthSun wrote on Yesterday, 15:04:
pete8475 wrote on Yesterday, 04:33:
XP – modernized (I am not permitted to specify the exact version here, but those familiar with "modernized" XP will know)
What and why?
I posted a link to it here once, but the local moderator deleted it. It contains a serial number, so I assume that’s why. Although, in my opinion, anyone who has the original installation disc or a license should be able to install it...
I can send it to you via private message, if you’d like.
I can totally understand not linking to pirate software but you wrote "not permitted to specify the exact version here" did a moderator say that? Sounds like a bizarre overreaction to me.
aka pete4237.5
Reply 24 of 33, by DarthSun
pete8475 wrote on Today, 01:02:
What and why?
He didn't say anything, but when I looked back, I saw that "removed" appeared where my link had been.
Reply 25 of 33, by Condor.07
What I see in this image on GPU-Z is not encouraging...
download/file.php?id=253113&mode=view
You have a PCIe 3.0 that is running at 1.1
But setting aside the dry data—which, in my personal opinion, isn't all that useful...
Tell us about how everything is managed.
How do you boot up the various operating systems, and how do you handle the dual graphics cards?
That’s what really makes the difference in a multiboot system.
For instance, I once saw a YouTube video by PC Madness that highlighted quite a few issues—but that was 10 years ago, and technology has improved tremendously since then.
Reply 26 of 33, by Falcosoft
Condor.07 wrote on Today, 10:58:
It's the way it should work when the GPU is not under load. Next to the 'Bus Interface' data field there is a question mark where you can start a heavy load test. After you start it the current value should change to x16 3.0.
If not, then there is a problem. Check on your system.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 27 of 33, by Ydee
Falcosoft wrote on Today, 11:31:
Indeed, it is 2D state, so no need full clock GPU/MEM (as could be seen on MSI Afterburner) and PCIEe 3.0, it is power saving features.
Reply 28 of 33, by NeoG_
Tough crowd. Although I guess when you say your system is the king it will probably attract scrutiny.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 29 of 33, by DarthSun
What I see in this image on GPU-Z is not encouraging... […]
One option is the UEFI boot manager (accessed via F11 on this motherboard), or the Linux Garuda GRUB—the latter allows me to include all my SSDs and operating systems (there are 5 SSDs in the machine). Alternatively, I can enter the UEFI and select the desired boot sequence. In the case of two of these systems, entering the UEFI is necessary anyway: for DOS, a 2-core/2-thread configuration is recommended (in my opinion), while XP supports a maximum of 16 cores/32 threads—since the 2699 has 18 cores/36 threads, disabling Hyper-Threading (HT) is worth considering.
I liked this motherboard so much that I ordered another one; I now have two. The second one is currently on my test bench, equipped with an E5-2697A v4 processor (16 cores/32 threads), which means the approach is slightly different in this case. It also has an RTX 3060 installed for testing purposes—though both the board and the CPU will be tucked away in a drawer afterward, serving as a "joker" spare.
The attachment 2697.jpg is no longer available
The attachment Probe_4x8_DDR4_img_20261114_221558.jpg is no longer available
The attachment Soyo_3060.jpg is no longer available
The attachment MR9S_2.jpg is no longer available
The attachment PPad_new_MR9S_img_20261115_053039.jpg is no longer available
GPU-Z: as described, it shows an idle state (under no load).
Reply 30 of 33, by DarthSun
NeoG_ wrote on Today, 12:26:
I’m only a snob and a megalomaniac when it comes to computing (as a hobby); in other areas, I’m more of a plain, ordinary citizen.
Reply 31 of 33, by Condor.07
Modifying the BIOS at every startup is not necessary, but the GRUB2 bootloader manager does not support a mix of UEFI and Legacy modes.
Reply 32 of 33, by DarthSun
Condor.07 wrote on 36 minutes ago:
I didn't even know that; I'll throw in the retro ones too, just to test—I recall they worked fine on another machine (X299). Both UEFI and Legacy are enabled in the BIOS.
Reply 33 of 33, by DarthSun
We haven't looked at XP yet. Let's check it out.
Note: We take a modernized version of XP (I can only share the link via private message) and integrate it into a new ISO, selecting the necessary drivers for the specific hardware—AMD/Intel, AHCI, NVMe, USB 3.x, etc. A configuration tool is included in the package.
Let's see the results: a general desktop/retro test (CPU with 18 cores/18 threads; Hyper-Threading off, Turbo Boost not working under XP—though it can be configured for 16 cores/32 threads with Hyper-Threading enabled, as the system supports a maximum of 32 threads).
The attachment X99_2_Új_Asztal.JPG is no longer available
The attachment X99_2_New_3DM01.JPG is no longer available
