Reply 40 of 55, by myne
No. 3.x has a setup utility available from dos to fix things.
It's like a primitive safe mode.
Eg c:\windows\setup.exe
Though it might be in windows\system
I built:
Reply 41 of 55, by ldeveraux
myne wrote on 2026-04-25, 02:45:
No. 3.x has a setup utility available from dos to fix things. It's like a primitive safe mode. […]
was this to me?
Reply 42 of 55, by myne
Was there someone else?
Did you try it?
I built:
Reply 43 of 55, by ldeveraux
myne wrote on 2026-04-27, 02:04:
Did you try it?
If I'm not quoted, I don't assume anything is directed at me. Like this comment. I didn't try it as I didn't understand it.
Reply 44 of 55, by henk717
ldeveraux wrote on 2026-04-15, 14:18:
henk717 wrote on 2025-03-28, 13:15:
Correct yes, I even redownloaded Windows 3.11 for Workgroups OEM as well as MS-Dos 6.22 in case it was an issue with my own version I already had.
When making the template disk I use ultraiso with the no to all option.
Wondering if you ever got this sorted? I know OP doesn't provide support, but I'm in the same pickle.
No, I never got it to work.
Reply 45 of 55, by myne
I'd be curious to see screenshots of each step.
There are only 4 main steps
I built:
Reply 46 of 55, by ldeveraux
henk717 wrote on 2026-05-12, 22:24:
I'm probably just going to brute force install DOS and Win98SE at this point. We're dealing with 30 year old systems and OSes, and I miss the modern conveniences associated with modern installation. That and minor hardware compatibility issues is throwing me considering I'm installing to real hardware.
Reply 47 of 55, by myne
Test it in a vm.
If it works, copy to real drive and see what happens.
Frankly, I'd upload a full iso and hdd image if it would last more than 3 seconds before deletion
I built:
Reply 48 of 55, by Duffman
@myne
Can you consider adding these to your template?
https://github.com/ages2001/WINAUDIO
https://github.com/ages2001/WINUSB
https://github.com/ages2001/WINDISK
https://github.com/ages2001/WINVBE
WINDISK should go all the way to 2TB too, but that would need swapping DOS 6.22 for 7.10.
for ISO upload you can try - https://buzzheavier.com/
should stay up if enough people download
What do you think?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 49 of 55, by myne
I don't really have the time to test it right now.
But they all have oemsetup.infs so it should be relatively straightforward to add them to the only 4 setup files I modified.
I'd start with setup.inf. I'm pretty sure the rest aren't relevant
I built:
Reply 50 of 55, by analog_programmer
Why don't you replace the floppy disk image ([BOOT]\Boot-1.44M.img) containing an illegal copy of m$-DOS 6.22 boot/setup "DISK 1" contents in your ISO "template" with something that complies with the forum rules like SvarDOS, freeDOS or even ST-DOS from lEEt/OS?
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 51 of 55, by LSS10999
analog_programmer wrote on Today, 07:09:
Sadly for Win3.1x 386-Enhanced Mode I've no success with other DOSes than MS-DOS especially with modern systems.
Unless we have a legal, non-MꟌ DOS environment that can reliably be made work with Win3.1x 386-Enhanced Mode, MS-DOS (6.22 or 7.10) is the only option for now.
PS: Win3.x setup does not require 386-Enhanced Mode, so most DOS kernels including FreeDOS can be used for performing installation (both text-mode and GUI portions) but only MS-DOS can be used for actually launching Win3.x for now.
Reply 52 of 55, by myne
What's the dir list of both?
I recall building it from a standard boot floppy and a few necessary files like setup, but it refused to work without the exact dics name.
My memory is old though.
That said, I suspect fairuse covers it well enough. It isn't standalone. It cannot work without the user supplying the additional required files and presumably 40yo license stickers.
I built:
Reply 53 of 55, by analog_programmer
LSS10999 wrote on Today, 11:16:
Sadly for Win3.1x 386-Enhanced Mode I've no success with other DOSes than MS-DOS especially with modern systems. […]
I only meant the installation "template" iso-image. It contains floppy bootable image with m$-DOS 6.22 files and this is against the forum's rules.
For example MiNiDOS thread was cleaned and locked for just three core m$-DOS 6.22 files, but here we have the entire m$-DOS "DISK 1" diskette contents. I will just wait to see the mod's double standards (again).
Reply 54 of 55, by LSS10999
analog_programmer wrote on Today, 12:55:
I haven't used MS-DOS 6.22 for a while... I recall its SETUP was a bit tricky to get working.
It probably have checks for something outside known files, as when I tried making a physical backup copy of the MS-DOS 6.22 install floppies, by formatting the blank floppy and copying all the files on the MS-DOS install floppy disks as-is, SETUP refused to recognize the newly made floppy (and kept asking for DISK 1). I think I did make the new floppies' labels the same as the original MS-DOS install disks.
It was very long ago and I had no experience with disk imaging utilities back then. That certainly was a *wrong* way to make backups anyway.
To not use MS-DOS 6.22 for booting one would have to write their own install routines instead of relying on DOS 6.22 SETUP, like EXPAND-ing files, copying them, setting up boot sectors and config files. However, I'm afraid DOS 6.22's SYS would not run on any DOS kernel that reports a newer DOS version leading to "Incorrect DOS version" error.
Reply 55 of 55, by analog_programmer
LSS10999, as I already wrote, the floppy image with the illegal m$-DOS 6.22 content is for the bootable CD floppy emulation, not for m$-DOS 6.22 installation (which is the first "phase" of this CD image "template"), so it is hidden inside the "[BOOT]" directory. At first sight the attached iso-image is "clean" from pirated software, but the m$-DOS floppy image is already part of it (the bootable part).
Do not be an advocate to someone, who is now "silent", because he/she knows very well what was used for this DOS-bootable CD image creation, and that such iso-image should not be attached or linked here.
