First post, by dreamblaster
Coming soon :
SerdaVision VGA - 8-bit ISA video card with analog VGA output
The VGA version of SerdaVision: same card, same firmware, now with a real analog VGA output. Emulates the original video hardware, the picture goes out as RGB 6-6-6 through latches and resistor ladders, just like the DAC of a real VGA card.
Plug in your old CRT or VGA LCD and it gets the timings it expects.
Available soon at https://serdashop.com/products/serdavision-vga
Firmware 1.01 is in beta now, release coming soon
Video standards supported
- VGA, EGA, CGA, Hercules, MDA
- VGA-XT and EGA-XT for 8088/V20 machines
- SVGA: VESA 1.2, up to 800x600x16 and 640x480x256, 320x200 hi-colour, optional ET4000 or Paradise mode
- Experimental: Plantronics ColorPlus, Olivetti PC1, Tandy 1000/PCjr, Hercules InColor
Highlights
- Real VGA timings: 70 Hz for 200/350/400 line modes, 60 Hz for 480 lines, 800x600 at 56 Hz, 262144 colours
- 15 kHz RGB for TVs with a VGA to SCART cable, switch from DOS, the menu or the button
- Fast: up to 2.1 MB/s write with 0WS on a 430HX, 0WS on/off right in the on-screen menu
- Settings kept in flash, firmware updates over USB-C
Tested on a Pentium and a V20 XT: every card passes on both.
Limitations: 8-bit ISA slot only; mid-frame palette changes are not shown; no light pen.
Availability and price: see SHOP-LINK
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
