Reply 3580 of 3586, by robertmo3
if you look at billboards here:
https://youtu.be/l0h27lGANUI?t=161
they certainly have at least four levels of details
also the building here have at least two levels of details:
https://youtu.be/l0h27lGANUI?t=275
I didn't force MIP level 0, only high detail for everything in every sector. Before the area around the player/camera is in high detail, the next few sectors at medium and the furthest away at low. Now everything is at high, but not mipmap 0. I do have a build for that but it would probably be even slower.
I'll post the whole lot I produced through Claude.
https://nirvtek.com/downloads/IndyCar2-Rendit … d%20%283%29.zip
MD5: d444d6d1e1e84a06a0628ce44cbe4701
I think what you're looking for is the mip0 subfolder.
In the meantime:
Nascar Racing 1999 Rendition Edition should be able to open custom tracks with this:
https://nirvtek.com/downloads/Nascar1999.MemL … ved.20261126.7z
MD5: 437a057008caeb01017bc79e41c2c2ac
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
i think it shouldn't be slower, because it is probably done completely by gpu. so maybe worth a try.
robertmo3 wrote on Today, 14:02:i think it shouldn't be slower, because it is probably done completely by gpu. so maybe worth a try.
K, will try it now.
By popular request, mipmap 0 and it's slower:
https://youtu.be/32Ua3gmqvAI
vHexen II Golem colour change, partially broken fix:
https://youtu.be/u9T1VzGldFU
