Reply 40 of 45, by Mondodimotori
Warlord wrote on 2026-11-19, 18:01:
14 and 15 irq should not be legacy isa, both need to be pci/isa. Disable usb and don't assign irq for it if you don't need it […]
14 and 15 irq should not be legacy isa, both need to be pci/isa. Disable usb and don't assign irq for it if you don't need it, it could be irq sharing with the nvidia card. video bios cacheable and video ram cacheable should be enabled those boost performance.
what could be happening i dont know is setting irq 14 and 15 to isa, forces the ide controllers on to 10 and 11 along with the usb controller and the vga card which is not good.
IRQ	Standard Assignment	Notes
IRQ 0 System Timer Internal Intel 8253/8254 timer; cannot be reassigned.
IRQ 1 Keyboard Controller PS/2 or AT keyboard interface; cannot be reassigned.
IRQ 2 Cascade to Slave PIC Routes signals from IRQs 8–15 to the Master PIC.
IRQ 3 Serial Port 2 (COM2) Often shared with COM4.
IRQ 4 Serial Port 1 (COM1) Often shared with COM3.
IRQ 5 Parallel Port 2 (LPT2) / Sound Card Default choice for legacy ISA sound cards (e.g., Sound Blaster).
IRQ 6 Floppy Disk Controller Dedicated to floppy disk drives.
IRQ 7 Parallel Port 1 (LPT1) Primary printer port; occasionally used as an alternate sound card IRQ.
Slave PIC (IRQ 8–15)
IRQ 8 Real-Time Clock (RTC) Internal CMOS clock; cannot be reassigned.
IRQ 9 Redirected IRQ 2 / ACPI Software-redirected to replace IRQ 2; used for ACPI on newer chipsets or open for peripherals.
IRQ 10 Available (Open) Commonly used by SCSI adapters, network cards (NICs), or USB controllers.
IRQ 11 Available (Open) Commonly used by SCSI adapters, NICs, or video cards.
IRQ 12 PS/2 Mouse Available for peripherals if no PS/2 mouse is installed.
IRQ 13 Math Coprocessor / FPU Handles floating-point unit errors; cannot be reassigned.
IRQ 14 Primary IDE / ATA Channel Controls primary hard drives and optical drives.
IRQ 15 Secondary IDE / ATA Channel
Great! Thank you for the detailed answer, I'll test these modifications to BIOS tomorrow evening and I'll let you all know.
I've also disabled parallel and serial ports alredy, will do the same with USB, since it's 1.0 and quite pointless to use. I may put a network card in it and run an FTP server of my NAS (it's isolated from the internet).
But shouldn't this issue present itself with all GPUs instead of escalating from one GPU to the other?
Intel486dx33 wrote on 2026-11-19, 19:26:
I am pretty sure I was running windows 95 on my Celeron CPU’s build.
I also had a AMD k6-2@300 mhz build running windows 95
These were popular with budget Gamers.
I have yet to install the OS since I lack a free flopy drive and cable, it should be coming soon though, and I was thinking more and more about 95 since it has pretty good compatibility with DOS games loading from inside it and, if needed, booting directly into DOS mode.
Reply 41 of 45, by Warlord
not necessarily.
Reply 42 of 45, by Mondodimotori
Warlord wrote on 2026-11-19, 21:18:
not necessarily.
Ok, I've tested fixing up the IRQs as you suggested, but nothing changed.
I couldn't find a "disable USB" directly in BIOS, so I just disabled the "Assign IRQ to USB". I also enabled both video bios cacheable and video ram cacheable.
Guess I can only try updating the BIOS but, first, I'll try installing Windows 95 and see how it performs in there.
Unfortunately the sound card is still on the way.
Reply 43 of 45, by eliot_new
Mondodimotori wrote on 2026-11-10, 21:15:
Hello there, in an attempt to escape my troubles with late AGP cards, I decided to get out of my comfort zone and get a computer […]
Hello there, in an attempt to escape my troubles with late AGP cards, I decided to get out of my comfort zone and get a computer that is (slightly) older than anything I ever used growing up. I started my PC adventures on a cheap 462 board and another 370 board, thus a Slot 1 system is nothing I ever had my hands on before.
So... What did I get? For the price of 30 € I got myself a:
  • QDI P6I440BX/B1S, with Intel 440BX chipset and BIOS revision 1.1SLR (from November 1998). 4 PCI slots and 3 ISA slots, capacitors mostly fine (maybe a couple of them near the CPU are not entirely flat, something I'll take care in the future)
  • Mendocino Celeron 333mhz
  • 64 MB of ̶E̶D̶O̶ ̶r̶a̶m̶ SDRAM (gotta check the speed)
  • Trident Blade 3D 9880 turbo AGP
Now, since I alredy have a couple 9x systems ready (a 462 with Athlon XP 2500+ and a 370 with a P3 1000), I was thinking about turning this system into a very early 9x system or direclty a late DOS system to play mostly 3D accelerated DOS games and, maybe, some non speed sensitive 2D games. What do I need to get for this plan to come to fruition?
Currently I had my eyes on the following upgrades:
  • The CPU: I feel this Mendocino Celeron is plenty fast for my goals but... If I ever feel the need to slow it down to play speed sensitive DOS games, it doesn't leave me much options. The motherboard actually has some decent settings for the CPU, with a "Jumper emulation" mode that let me chose freely both the FSB and multiplier of the CPU. Except... The CPU happily ignores any settings that changes the default 5X multiplier. If I bump up the FSB, I see the increase in clocks, but 66mhz FSB is the bare minimum, and lowering the multiplier doesn't achieve anything.
    Except from disabling the L2 cache to achieve slower operations, is there any Slot 1 CPU that would respond to changes in the multiplier?
    Because the board can happily set me with a 66mhz FSB and a 2X multiplier, and I was reading that early Pentium 2s from 1997 do come with an unlocked multiplier. Would they be a good option? And which models exactly? Considering that I wouldn't even need a BIOS update to use them, since my BIOS is from late 1998 alredy.
    Or there are better options to slow down the CPU? Or should I just stick with disabling the L2 cache and call it a day, since I don't really plan to play lots of speed sensitive games?
  • The GPU: Probably the easiest part: I have an history of love/hate relationship with the Trident Blade 3D, since it was the IGP in my first ever desktop PC that I used all the way up to 2009 (and young me insisted in playing games on it), but from what I read it's mediocre both in 9x 3D acceleration and DOS gaming. Thus I peeled my eyes for two options: A cheap one and a not so cheap one.
    The cheap one is a GeForce 2 MX400, hopefully one with a 128bit bus (apparently not easy to spot, since some cards with 8 memory chips on them are still 64bit only) or, if truly desperate, a TNT2 M64 (alredy got one, but has fuzzy VGA output, and they are plentifull on ebay for dirty cheap).
    The not so cheap one is the obvious: A 3dfx card, either a Voodoo Banshee or a Voodoo 3 2000, which should be plenty fast for 3D DOS acceleration.
    On the side I plan to get a card for 2D games like an S3 Virge/GX2 or S3 Trio 64 on the PCI bus, also plenty cheap online. Maybe I'm even able to install both PCI and AGP at the same time?
  • The RAM: I don't feel I need more than 64MB, ̶e̶v̶e̶n̶ ̶i̶f̶ ̶i̶t̶'̶s̶ ̶E̶D̶O̶. But in the offchance I should feel limited, I alredy have some PC100 and PC133 kits ranging from 64mb, 128mb and 256mb around.
  • The sound card: Probably the hardest part since I was never really interested in dedicated sound cards before, just getting an X-Fi PCI for my XP retro rig. But I still managed to make myself a short list by lurking old threads here on the forum.
    I'm currently looking at several ISA options, since I don't really need them for 3D sound acceleration, but only good compatibility and clean output (as clean as one can reasonably get).
    And it gets confusing pretty fast with the options I found, which are:OPTi 82C930A / 82C929A / 82C928 / 82C931; CMI8330A; Compaq ES1868; Terratec Promedia Soundbooster 16 3D; AudioDrive ES1868F; Crystal CX4235; Soundblaster Vibra 16C (CT4180), Aztech AZT2320
    As you can read, there are many options, and all of them I can get for reasonably cheap were I live, and as I said I'm extremely confused by the variety. What do you think is the best compromise of DOS compatibility and good audio output among all of those? Considering I won't go with very old DOS games, mostly 3D accelerated games and some 2D game of the "transition to 3D" period.
  • And the OS... I was thinking playing it safe with 98SE buuuut, I alredy have a system that is perfect for 98SE (the Pentium 3 1000 on 370, it has one ISA slot), and I was thinking about something older, so... Does Windows 95 or straight up MSDOS 6.22 make sense?
Well, I guess that's that. What are your opinions on my planned build? Different CPU? Different GPU? Maybe one of those Sound Cards is actually more than decent for my plans or a stand out I should seriously consider?
I'll try to be consistent this time and, while I acquire parts, I will post updates, since I'll probably move one attempt after another with a platform I'm not familiar with at all. On the list of things to get there's also a "new" floppy drive and another IDE CD drive, since I just discovered that my "working" IDE CD drive is actually "spinning but not reading".
Here are some pictures of the system on it's current test bench, were it'll proably sit until I gathered all the needed parts:
SetUp Pictures
The attachment 01.jpg is no longer available
The attachment 02.jpg is no longer available
The attachment 03.jpg is no longer available
The attachment 04.jpg is no longer available
Excuse me the full quote but I m sitting in a train and typing in my phone.
1. I have exactly the same board QDI BrillianX 440BX S1 with the latest bios. It can handle max P3-600 Katmai. The BrillianX without S can also Coppermine but only the latest revision
2. I have paired it with P3-450 Katmai, 768MB SDRAM, V3-2k AGP, AWE64value, Win98SE dualboot MSDOS6.22
I can recommend the AWE64 value as it is cheap. I bought 6x of it the last 2 years always waiting 4 a good ebay price ~ 45...50 €. It can AWE32,SB16,SB 2.0 but not Pro 2.0. Furthermore it has pseudo 3D acceleration in its driver what sounds really ok e.g in DeusEx1.
This was my entry Retro rig 2 years ago. Later I I stalled also a PicoGUS 2.0 but now it is part of my P233MMX rig as there is no use in running the very old apogee gems on a P3-450.
PS: in case you want to run early 3dfx games w/o issues you can install a TNT2 AGP card and pair it with a V1 4MB 3dfx card. I have 3x V1 4MB, 1x V2 12MB, 2x V3-2k AGP 2x V3-3k AGP, 1x V3-3k PCI, 1x V4 4500 AGP. Xmas I will sell half of it as it is too much. If you live in Europe you can send me a PM.
DOS:P233MMX,64MB,ECS,SpeaMirageV7,3dfxV1,AWE64,ESS1868,PicoGUS,32GB
W98SE:K63/400,256MB,P5A,Verite2200AGP,3dfxV2,M3D,AWE64,ESS1938,PicoGUS,64GB
XP:P3-1G,512MB,CUSL2C,FX5600AGP,Audigy1,80GB
Reply 44 of 45, by Mondodimotori
eliot_new wrote on 2026-11-21, 17:34:
Excuse me the full quote but I m sitting in a train and typing in my phone. […]
Don't worry, and sorry for my late reply. I've had some issues with floppy drives, hard drives and BIOS updates (more on that in a bit)
Now, point 1:
Yup, mine is also a 1S, it accepts 1S bios updates, including latest BETA bios (more on that in a bit!)
Point 2:
I got myself an ESS audiodrive, but I have yet to test it since I have yet to install an operating sistem (yup, u guessed it, more of that in a bit). I plan to also get some OPL3 sound card.
Now, if you wanna sell your hardware, I also live in Europe, and even inside the EU, Italy, so no taxes if you are also inside the EU. I could be interested if Christmas bonuses and my last invoices gets paid before the end of the year. If you want I can send you a PM or, if you're gonna sell them on places like ebay, I have an active buyer account there.
Warlord wrote on 2026-11-18, 06:48:
...check you have the latest bios. latest bios is from 1999 i think,
Well, you know how I said I didn't want to update BIOS if not strictly necessary? Well... I had to do it when I tried connecting an 80GB IDE HDD to this board.
POST screen hanging at "detecting primary master". I try switching IDE cable, power cable, all the stuff. Nothing. "Autodetect IDE" in bios also hang not finding anything.
I try and switch to a 40GB HDD, reading online that some of these old boards won't support more than 75GB... Still hangs.
I search more and on some old forums I find that some of these boards have even issues with HDD larger than 35GB, especially with older BIOS revisions.
I pull out a 20GB HDD from a 370 system (casually also on a QDI board), I put it in... AND IT WORKS.
So, I decide it's time to update this goddang BIOS and see if I can make this 80GB HDD work.
I decide to try the latest stable version, V2.1SRL, downloading it from The Retro Web, flashing it and... Nothing. Still hanging at "Detecting primary Master".
But while it hangs I notice something: POST screen says V2.0SLR. I was sure to have downloaded V2.1SRL... And there I notice that the link on The Retro Web for V2.1SRL downloads the 2.0 SRL, just like the link for 2.0SRL. I scream.
I look for V2.1SRL online, find it on an old website still online and, in the changelog, I read "added support for large HDD". EUREKA! I download it, flash it and... HOORAY! I see the drive and it goes past POST! I do a victory run... Only to come back to the system hanging at the screen immediately after POST, not booting the floppy still inserted. I try going into BIOS into "Autodetect IDE", and there it hangs after noticing there's actually a drive connected.
I decide to go all in. I bite the bullet and I download the latest BETA BIOS. From February 2001. V2.2SLRB.
I install it. Goes fine, the hard drive still shows and, this time, even "Autodetect IDE" works!
I finally can boot into my 98SE boot floppy and can format the drive with FDISK!
After three hours, at almost midnight, I decide to call it a day... Tomorrow I'll try install Windows 95.
Reply 45 of 45, by Mondodimotori
Ok, apparently I really can't catch a break.
Maybe this Motherboard is toast or close to being toast.
FDISK command more often than not hangs after I launch it, It just never shows the "large drive" screen, the floppy just stops making sounds and no new DOS command line appears.
This is on any boot floppy I use (Win98SE and WinME), no matter what HDD I connect (tested 80GB and 40GB), or what IDE of FDD cable I use, no matter the PSU, and even without an HDD connected. Sometimes it just doesn't move.
On every other PC, with all my functioning floppy drives, with any cables and with different HDDs, FDISK just works.
What could be the issue here? Becuase yesterday evening everything was working fine after the BIOS updates. It did happen ONCE that FDISK hanged, but I didn't give it much thought.
This evening, mind set to finally install Win95, it kept hanging. And hanging. And HANGING. I spent hours trying every possible combination.
At the end I just started rebooting the system on repeat until it finally started, and currently I'm creating the DOS partitions. I'll update if it actually succedes or it hangs midway. Because if it works no issues all the way through... I would be speechless.
I don't feel I need to make a thread about it, so I'll try posting this question in this thread, since it relates to this Motherboard only. I'm also very close on giving up on this build and any other older build, because I can't believe I just spent last Saturday and, now, 4 evenings in a row bashing my head on hardware problems, from Floppy drives, to HDDs not recognized and, now, DOS commands not working from boot floppies.
EDIT:
Ok, I've performed more tests and... No good news.
While I had more success in launching FDISK by using a Windows Me OEM CD, it still hangs sometimes.
I even tested more PSUs, but still nothing. Something fails when it tryes to access the HDD. The Floppy led remains always on, while the HDD led shows no signs of activity.
And FDISK isn't the only one command hanging. After succesfully creating the partitions, I decided to just try and install Windows 95 and... Nothing.
Sometimes it hangs immediately after selecting "Start computer with CD-ROM Support"
Sometimes it hangs while checking the hard drive after launching SETUP from the CD.
Sometimes it hangs after doing the preliminary tests before te installation.
Currently I've never been able to enter the setup for Windows 95. And always with the floppy led stuck on, while the HDD led completely off.
Even using a bootable CD for Windows ME the result is the same. Sooner or later it will hang either before or during the installation process.
I even tested a different known working stick of RAM.
At this point I thin it's either a bad CPU or a bad Motherboard.
Either way, I feel this build is basically dead in the water as it currently stands. I don't know how I can go from "yeah, no problems after updating BIOS" to "ded" in a matter of 24h but... Here we are.
