Reply 2780 of 2788, by Falcosoft
- l33t
Roland User wrote on 2026-11-20, 13:56:But where I can recive banks for this ? )
VOGONS is not the right place to discuss this.
Here is a new VST 2.4 instrument plugin based on FluidSynth. As far it is possible it works exactly the same way as Bassmidi VSTi so it can be useful to compare the 2 Soundfont engines. Of course some options available in Bassmidi are not available in Fluidsynth and vice versa. So there are some differences in the setup dialog but the main working logic of the plugin is not affected that much by these differences.
Features:
1. Native x86 and x64 plugins, with both 32-bit and 64-bit audio processing.
2. Up to five stacked SF2 SoundFonts with bank offsets. Later enabled SoundFonts have priority when presets overlap.
3. Selectable interpolation: Off, Linear, Cubic, Sinc 11-point and Sinc 17-point.
4. Selectable reverb engines, including Dattorro, FDN, Freeverb and Lexverb. The list reflects the engines available in the loaded FluidSynth library.
5. Built-in chorus, with separate global reverb and chorus level controls.
6. Configurable polyphony, gain, CPU core count, sample preloading and portamento mode.
7. GS, GM, GM2 and XG MIDI modes, with optional use of bank 127 for XG drum kits.
8. GM Master Volume and Tone/Brightness (CC#74) support.
9. Thirteen VST parameters for options that are not, or not easily, controlled by MIDI.
10. Instrument and bank names supplied to hosts that support MIDI program names.
11. Virtual keyboard, MIDI controller controls, active/peak voice display, bypass and host preset/state saving.
Falcosoft wrote on 2026-11-24, 09:27:Here is a new VST 2.4 instrument plugin based on FluidSynth.
Nice, i don't need request the cc#7 to initial attenuation to ian luck anymore.
BTW, in bassmidi ¿Is possible add lindecvol only to specific additional soundfont? Chippy_Bank.gm (ported to SF2) in original synth some instruments uses Linear Decay/Release, but switching flag changes in the soundfont entirely.
Zenxia wrote on Yesterday, 14:42:Falcosoft wrote on 2026-11-24, 09:27:Here is a new VST 2.4 instrument plugin based on FluidSynth.
I do not think so. But if you use a DAW you can have as many instances of BassMidi VSTi as you want and you can set different soundfont flags on each plugin instances. But I'm not sure if lindecvol is exposed in Bassmidi VSTi or not. (AFAIR it is not but I'm not sure).
[quote=James-F post_id=499212 time=1463899181 user_id=32371]Here is a video of the bug:[url]https://www.dropbox.com/s/s5f55mt4z322rl2/Falcomsoft%20Midiplayer.webm?dl=0[/url]The bug occurs with these Warcraft 2 midi files:http://www.mirsoft.info/gmb/music_info.php?id_file=MjYxNQ==The bug does not occur in Bassmidi mode, only in software midi loop and real midi loop.The bug also does not occur when using the new Stop button and clicking Play.It occurs when the player move to the next song (Autopplay), clicking the file, or clicking the Next Song button.BTW, I use LoopMidi to rout to SC-VA.Using LoopBe1 it immediately detects a feedback loop with your player making it unusable, not so with other players.Thanks for the stop button, the GS Master Pan also works.I'll move to your player right after you fix this small bug and the feedback loop bug.
EDIT:
I analyzed you player with MidiOX and found the problem.
When I stop playing your player sends a HUGE list of every single note to Note Off, Sound Off.
If this huge list isn't finished loading and I start playing the song again there is unwanted interaction.
Other player (vanBasco) sends a short list of Channel 1-16 Notes Off, 1-16 Sounds Off, and a Reset command, NOT every single note on the keyboard.
If I use a real cable midi loop with my audio interface, your player is much MUCH slower and sometimes crashes, because with real midi there is a hardware buffer that sends the command one by one,
and it is very slow, may I remind you that Midi is OLD and SLOW. 😀
When stopping a song I have to wait 2 seconds for this long all notes Off list to go through the real midi loop.
Again (to emphasize), real midi loop is SLOW compared to a software loop, you can't send a million commands and expect snappy behavior.
I suggest taking the vanBasco approach and using Note Off and Sound Off per channel, not per note, for the sake of real midi users, and to fix this bug.
Also, sending a Reset sysex command after Stopping is important, which your player doesn't do.
vanBasco sends 1-16 Notes Off, 1-16 Sounds Off, and sysex Reset, when I click Play or Stop (right before playing a song and after stopping it).
Just copy that behavior for best results.
[/quote]
Thank you ) after this message I improve methods reset and close application in my MIDI Router , if possible , please , tell me whitch may be drawbacks of such a solution and how you see solution for fix drawbacks of such )
Falcosoft wrote on 2016-05-22, 15:59:If it could not fix your issue please, help me to find the root of the problem.
1. Please check that other normal midi output devices (e.g. MS GM/GS Softsynth) are also affected or the problem is SC-VA/loopmidi specific.
So test can not , MS GM/GS Softsynth NOT support reset , this simpl very a primitive and crude synthesizer , on such this is analogue Creative SoundFont and not more ) , that so why test so not possible )
This if you about Microsoft GM/GM soft synth in Windows )
Roland User wrote on Today, 09:35:[quote=James-F post_id=499212 time=1463899181 user_id=32371]Here is a video of the bug:[url]https://www.dropbox.com/s/s5f55mt4z322rl2/Falcomsoft%20Midiplayer.webm?dl=0[/url]The bug occurs with these Warcraft 2 midi files:http://www.mirsoft.info/gmb/music_info.php?id_file=MjYxNQ==The bug does not occur in Bassmidi mode, only in software midi loop and real midi loop.The bug also does not occur when using the new Stop button and clicking Play.It occurs when the player move to the next song (Autopplay), clicking the file, or clicking the Next Song button.BTW, I use LoopMidi to rout to SC-VA.Using LoopBe1 it immediately detects a feedback loop with your player making it unusable, not so with other players.Thanks for the stop button, the GS Master Pan also works.I'll move to your player right after you fix this small bug and the feedback loop bug.EDIT:
Other player (vanBasco) sends a short list of Channel 1-16 Notes Off, 1-16 Sounds Off, and a Reset command, NOT every single note on the keyboard.If I use a real cable midi loop with my audio interface, your player is much MUCH slower and sometimes crashes, because with real midi there is a hardware buffer that sends the command one by one,
Again (to emphasize), real midi loop is SLOW compared to a software loop, you can't send a million commands and expect snappy behavior.I suggest taking the vanBasco approach and using Note Off and Sound Off per channel, not per note, for the sake of real midi users, and to fix this bug.
Sigh...
To tell you the truth I do not even think I should reply to such extent of false claims of your so called 'analysis'...
But here are some:
1. Notice that not every synth supports All Notes off and All Sounds Off controller messages. But all symths support Note Off messages. But Note Off messages cannot turn off sustained notes. So the best strategy is what Midi Player uses since this way it can work some way with all kinds of Synths. Midi Plater only sends Note Off messages for notes that were activated by Note On messages. If your 'router' cannot handle these then the problem is with your router since Midi Player itself has been tested with various devices for more than 10 years and except your router no devices had a problem with this.
2. Midi Player always sends at stop that kind of SysEx message that is set in the SysEx reset option. So your claim that "Also, sending a Reset sysex command after Stopping is important, which your player doesn't do" is simply false.
3. Please, do not spam my topic with such nonsense and quote conversations from 10 years ago.
I'm sorry , this happened by accident , for some reason when I pressed on topic name , was I geted first page and did not notice the date
Loopbe has too sensitive feedback detection. I can trigger it just by playing cinco de Chocobo from ff7 pc every time
