Mechwarrior 2 Decomp/Recomp
Reply 160 of 178, by KHORG
On 1.1.155
re-tested on 1.1.57 and 2.5
  • The Clan decal on the right arm (from the view of the Dire Wolf) is sunk into the Dire Wolf's arm. Left arm is fine. It occurs with any clan emblem decal and no other mechs have this problem.
  • The Elemental which has been added as an option in Trials of Grievance can't fire either of its weapons, pressing space just changes weapon selection, but without the usual "clunk" noise which occurs when pressing enter.
  • Enemy mechs are appearing on radar approximately 6 seconds before the "Enemy Powerup Detected" notification is played. This can be seen on Blade Splint, Sable Flame, Burning Chrome and Velvet Hammer. From looking at the DOS version of Blade Splint, the audio notification should be played as soon as the enemy mech begins its powerup sequence and appears on radar, not at the end of its powerup sequence.
  • On Golden Spade, the Shield-Generator should not be rendered (as a red structure or otherwise) on Satellite View.
  • On Golden Spade, the Force Shield should not be rendered on Satellite View as a red structure. It instead has a large blue marker which is already present.
  • On Golden Spade, the Hellbringer, Summoner and Mad Dog are being spawned outside of the Force Shield. They need to be spawned at their correct locations inside the Force Shield and the Palace fencing.
  • When your mech is powering up, you're currently able to select a target before your mech comes fully online. This is shown on the radar minimap and the MFD displays the target once active. This isn't the correct behaviour, you should not be able to select a target using E, T or any other key until your mech is fully online.
  • Starmate mechs don't seem to have the ability to aim down (or presumably up), so they continually shoot over the top of turrets, e.g. on Golden Spade. They can definitely aim downwards in the DOS version.
  • Jumpjets do not appear to be working correctly, you should have the ability to slew the mech around and have it change direction whilst jumpjetting. But currently once jumpjetting, you're locked into a direction and cannot alter heading.
Reply 161 of 178, by Mikeyy00
KHORG wrote on 2026-11-23, 10:13:
On 1.1.155 […]
On 1.1.155
Most should be addressed in 1.1.56, its working on your darken textures when damaged and the crashed dropship going into 5 particles now.. Apparently fixed in 1.1.57.
Reply 162 of 178, by KHORG
On 1.1.57
Re-tested on 2.5
  • Your pilot is not going up in rank, although he does correctly accumulate "honor". So after successfully completing Wolf Trial 1, the Aftermath screen incorrectly states your new rank is "Mechwarrior" (which is the base rank). And the Pilot Register still lists you as a Mechwarrior, when you should have gone up to at least Star Commander.
  • In the Star Config screen in the Ready Room, you can add more Starmates than are allowed for the currently selected mission. These will be shown in the formation display, and are retained there if you exit this screen and return to it. They don't come with you into the mission however. Usually if you try to add more Starmates than the allowed limit, the button should just make a click noise and not allow you to add them.
  • Enemy mechs seem to be missing a camo texture effect on some (possibly all) maps. Definitely on the Trial of Grievance Garstedt map, enemy mechs should have a grey base coat, with green camo stripes. But these stripes are not present.
  • On Golden Spade, The Force Shield should not be opaque, e.g. the buildings/fences/mechs inside it should be rendered if they are within rendering distance. And the same for any buildings on the other side of it, which might be in rendering distance.
Well, chatgpt has tried to fix the overly-small lights on the monorail/dropship/buildings, but it's gone a bit too far in the other direction. E.g. below is monorail at maybe 500-600M, it's nothing but big red squares. Maybe it needs about 50% of this effect? The lights are still ok if you're about 100-200m away, but past that it tries to render them as big squares.
The attachment monorail2.png is no longer available
Falcon base has a similar effect.
The attachment falc_base.png is no longer available
There are some unsolved bugs still here:
Re: Mechwarrior 2 Decomp/Recomp
And one here:
Reply 163 of 178, by KHORG
Further on 1.1.57... it's added a darkened effect to mechs, but I think it's guessed at how much to use.
E.g. below is a screenshot from DOS where the leg has JUST been shot to the point where it turns red.
The attachment DOS_darken.GIF is no longer available
And below is a screenshot from the recomp. In both cases using small machine gun shots to just get it over the line.
The attachment recomp_darken.png is no longer available
Is claude/chatgpt able to have a look at the original code to see what the effect should have been like? It was called "damage shade" in some of the older documentation, although I guess if this is recompiled code, all the function names are gone.
Otherwise we'll have to guess at a percentage to tone it down.
edit, fixed in 2.5. I feel like some of the diffuse lighting being cast onto the mechs isn't quite there, but will look at that later.
The attachment recomp_shade2.jpg is no longer available
Reply 164 of 178, by Mikeyy00
KHORG wrote on 2026-11-24, 09:35:
On 1.1.57 […]
On 1.1.57
And one here:
1.1.58 up shortly, should fix all outstanding *the lights might need more tweaking
Re: damage shading, it claims it found the original values and has matched them like for like now.
Reply 165 of 178, by Mikeyy00
Mikeyy00 wrote on 2026-11-24, 15:08:
On 1.1.57 […]
On 1.1.57
And one here:
Edit: Specific fixes will always be listed here: https://github.com/BatMahn/MW2-Port/blob/main/CHANGELOG.md
Reply 166 of 178, by gashoneil
Hey, I hope you don't mind but I grabbed a copy of your code a few weeks ago and started poking around it. I always had a dream of having better ground and I really liked the way Delta Force 2 done voxel grass. There is no way I could have done something like that with the original engine but I took a little inspiration from your project as it has something that the original didn't - proper depth via a z-buffer. So for the last 2 weeks I fixed a bunch of stuff in your code. I just logged in tonight and seen this forum and realised you have been quite active and I have been looking at old code... and if you are using AI it is probably pretty different from what I am looking at now.
Things I fixed -for example excessive clipping of the mountains due to the overlapping polygons, refusal to support super widescreen resolutions like 5120x1440 and a few other bits. I am not sure if Q targetting is needing fixed or if it isn't just my bindings, it is on my list of things to look at. I also couldn't shoot the dropship at the end of Jade Falcon mission 3, damage didn't seem to register - I was just going to look at this to see if it is the targeting hit box that is off or something else.
In addition to fixing that... I added basic grass to a couple of levels (needs to be done on a level by level basis) and I had to recolour the mountains to make them more naturally blend in to the flat ground to make the transition seamless. I added a tactical map that shows the entire mission area with known targets on there with some basic detail about the damade thouhg it seems stretched in my really wide resolution. I added a really basic FPS mode where you can get out your mech and move around on foot / jumpjets. It is all pretty basic and I am only doing it for a bit of fun. If I get through the Jade Falcon campaign and get it all working well I might look at making new missions, it would be cool if you could hop out of a damaged mech at a base and get a new one. I also added a free mouse look option independant of the rotation of the mech's torse by holding [ctrl]. I am thinking some falling snow would be good on the ice levels.
Anyway just dropping a message to say thanks for starting this stuff off and hope you keep improving it. I have a Packard Bell from 95 still set up with an SSD and some other upgrades and the main reason is I keep hopping back into MW2 and Descent. My new grass worn't work on that machine but after all these years I am still finding more ways to enjoy MW2
Reply 167 of 178, by Mikeyy00
gashoneil wrote on 2026-11-24, 21:30:
Hey, I hope you don't mind but I grabbed a copy of your code a few weeks ago and started poking around it. I always had a dream […]
Don't mind at all, that's why it's there. There has been a ton of changes since then.. you might wanna rebase your stuff on the newer code, but totally up to you.
Reply 170 of 178, by Mikeyy00
Mikeyy00 wrote on 2026-11-25, 14:51:
KHORG wrote on 2026-11-25, 13:03:
I think it's left debugging messages again, virustotal is picking up the same thing:
https://www.virustotal.com/gui/file/4e002966a … a3975876e5da6a1
Removed on 1.1.62
ChatGPT claims it's at 98% parity with the DOS version. But it admits it hasn't checked every mission - I'll try and get it to.
After using it for a few days, it seems to be MUCH better at chasing down bugs vs the other LLM. I'll point it at Mercs tomorrow and see if we can get that polished a bit more too.
Reply 171 of 178, by KHORG
2.3 just doesn't even download, Windows Defender nixes it.
While we are here, would you be able to have a look at decompiling the wasm.exe and stripwld.exe files from \tools\ on the Mercenaries cd?
These are the two files used for compiling WLD files into BWD format before they get packed into a PRJ as part of making a mission.
There is various information out there around how to manually write the initial WLD files needed for a level, but not all of the level/planet codes are known/understood. Someone hex-dumped the exe years ago and found there were more in there than we have documentation for.
I feel like if we can get a codeset listing the functions and file parsing in the compiler, we can then use that with the existing WLD/BWD documentation to build a new BWD decompiler (two have been built over the years, but the first was lost and the second needs java installed).
We can then decompile all the existing MW2/Mercs levels and use them as baselines for building more.
Reply 172 of 178, by Mikeyy00
KHORG wrote on 2026-11-26, 09:16:
2.3 just doesn't even download, Windows Defender nixes it. […]
Sorry, debug crap will be stripped again in 2.4 (LLM keeps adding it back in).
It's working on redoing those two exes you mentioned above. I'll toss them on a new Github repo later today.
Edit: Done, v 0.1 located here: https://github.com/BatMahn/MW2-Tools
Ive had it do a writeup how missions work:
https://github.com/BatMahn/MW2-Tools/blob/mai … ocs/MISSIONS.md
Reply 173 of 178, by Mikeyy00
Mikeyy00 wrote on 2026-11-26, 14:07:
Sorry, debug crap will be stripped again in 2.4 (LLM keeps adding it back in). […]
Theres a new BWD-to-WLD decompiler that turns every shipped mission back into editable WLD source that recompiles byte-for-byte identical. It also includes docs on every WLD command, including the 43 the official guide never covered, and how missions, planets and palettes fit together, with prebuilt Windows, macOS and Linux binaries.
Reply 174 of 178, by KHORG
Thanks for that, I'll have a look at those tools.
On 2.5
  • If there is only one mech in the player Star, then in the Star Config screen, when you click "Next Formation" - depending on the new formation layout - it should move the text, the "Change Mech" button and the bounding box which surrounds the two. But currently it only moves the text. Some formations have the widget in the same screen position as the default Echelon Left, but most need to move the widget around the screen.
  • This goes further wrong if you have a Star of 3 mechs. If you click "Next Formation", it will swap the text around on the screen, but not the "Change Mech" buttons. So clicking "Change Mech" above your own mech might give you an edit screen for your own, or for a different Starmate's mech.
  • Friendly Starmate mechs will accept orders to attack enemy Mechs or enemy Turrets, but will not target/attack buildings/structures when they receive an "Attack my target" order.
  • Correction to a previous bug report, the Force Shield on Golden Spade is a flat-shaded structure, it renders as opaque to the player in that it does not allow the sky or ground behind it to be rendered. But it does allow structures/mechs inside or behind it (provided they are within rendering distance) to be rendered.
  • The "No Collision Damage" setting is flipped, when turned to On, the player does take collision damage, and when turned Off the player takes none.
  • The two door objects on Cold Crescent should not appear on radar as blue blips.
  • The Recon Helicopter on Silent Thunder should break into large and small pieces of debris when destroyed, but is currently only creating the small debris.
  • The lights on the monorail/dropship/buildings are now closer, but could perhaps still be 50% smaller than they are.
Reply 175 of 178, by Mikeyy00
KHORG wrote on Yesterday, 09:32:
Thanks for that, I'll have a look at those tools. […]
On 2.5
Should be addressed in 2.6.
Reply 176 of 178, by KHORG
Same thing again with virustotal. I'm not sure what your workflow is, but maybe there's a way claude/chatgpt can include an upload/verification to there as part of it's final compile.
These bugs were meant to have been fixed on 1.1.58, but are still present as of 2.5:
Reply 177 of 178, by Mikeyy00
KHORG wrote on Today, 00:30:
I specifically told it to strip it. But LLM's are great bullshitters. I'll push a new version in a few hours.
Reply 178 of 178, by KHORG
Looking at those tools, would it be possible to add a method onto bwd2wld so it can convert a specified windows directory of BWD's back to WLD?
The MWM option is good, but only useful for Mercs. And I've tried using the /all on MW2.PRJ, but it gets confused with the non-mission BWD files it finds (Activision were a bit terrible with their file structuring) and then just spits out all the mission files with incorrect names based on various aircraft/mech limbs. E.g. I now have fm1_head.wld (Firemoth head?) with navpoint data in it.
