KHORG wrote on Yesterday, 01:28:Back on those Bone Machine turrets, are you able to ask chatgpt if there are any BWD scenario files (SCN) where a Star has been […]
Back on those Bone Machine turrets, are you able to ask chatgpt if there are any BWD scenario files (SCN) where a Star has been assigned a DEFEND order, but no DESTROY orders? Specifically in the SCN file, not the other BWD files containing the gp_spec for the AI.
The Bone Machine turrets are setup like that, but I suspect DEFEND is only meant to be used as a trigger (e.g. mission succeed/fail for the player star and change-to-next-objective for AI stars), not to drive who the AI attacks.
Normal enemy turrets have orders to DESTROY the player star.
That said, this order has do-not-disturb=zero, so in theory the turrets should return fire if attacked (they don't in DOS/decomp). But maybe the engine interprets this differently for AI mechs versus other gamepieces (turrets, tanks, dropships).
GPT:
The Bone Machine turrets are the only turret star in MechWarrior 2 or Mercenaries whose only real order is DEFEND. Bone Machine is the Fuchsia mission (fuch files), and its Star 4 is four "Falcon Turret"s with BEGIN and DEFEND Fuchare1, mechs-per-target 0 and do-not-disturb 0.
Every other MW2 star with DEFEND but no DESTROY or ANNIHILATE
Turret stars that do shoot always have a DESTROY order in both games, usually aimed at the player star. That's 16 turret stars in MW2, and the same pattern in Mercs.
That fits your theory, and Activision's scenario guide on the Mercs CD (MW2DOC.HTM) backs it up:
DEFEND is described only as a condition: it fails when a protected object is destroyed, and succeeds on time-out or when another objective forces it. Nothing says it picks targets.
Do-not-disturb says 0 means "send out gamepieces to fight" enemies in range, and ends with "This applies to AI mechs only."
So turrets with only DEFEND and dnd 0 not returning fire is consistent with the original design. Either the Bone Machine setup is a data mistake (it would need a DESTROY to shoot), or it's deliberate and they're meant to be passive.
The closest comparison that does shoot nothing deliberately: turrets with no DESTROY at all, only WAIT. That's red_ Star 6 in MW2, and the artillery turrets in Mercs lut3/lut6. If DOS footage shows those never firing either, that confirms turrets don't attack anything a DESTROY order doesn't point them at.
