Reply 340 of 347, by Duffman
vico wrote on Yesterday, 06:17:
The screen resolution is set to 1024x768 with 16-bit color.
Croc is configured to use Direct3D at a resolution of 1024x768.
My PC keeps freezing even though I uninstalled Velocity; I’m going to run further tests to find the cause.
WINUSB would be the cause, open an issue up on ages2001's github to have it fixed.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX3090 (11) GT730 (XP)
Reply 341 of 347, by Dothan Burger
mwdmeyer wrote on Yesterday, 11:26:
myne wrote on Yesterday, 11:21:
Plenty of us have run it. So far I think he hasn't haxx0red the gibson. […]
He's been a member of OCAU for nearly 25years.
https://forums.overclockers.com.au/members/mwd.19405/
Here, 14.
Now, maybe he IS building a botnet the slow way by getting video cards working. It just seems inefficient.
Haha that sounds like the slowest way to build a botnet, no multi-core support or anything fancy!
For doing the driver it normally only takes 24-48hrs, so if you can leave on for a day or two I can create you a basic 3d driver.
How do I get the remote agent?
Reply 342 of 347, by myne
https://github.com/michaeldale/V9x-Remote-Agent
I built:
Reply 343 of 347, by mwdmeyer
vico wrote on Today, 00:13:
Croc looks much better now, though there are other graphical glitches: some objects, text, gems, and even the lava appear inside […]
mwdmeyer wrote on Yesterday, 09:52:
Great thanks for the update.
I've attached a new test build for Croc, if you get time please test, send through another trace if any issues.
Croc looks much better now, though there are other graphical glitches: some objects, text, gems, and even the lava appear inside a black box. I also tried 'Gex: Enter the Gecko,' but I couldn't get it to launch—not even with the 3D patch.
I also tested Earthworm Jim Special (a 2D game), and there are some issues that I will report later.
marxveix wrote on Yesterday, 14:11:
You can use xusbsupp, its the win95b/win95c (osr2.0/osr2.1/osr2.5) version of nusb. https://vogonsdrivers.com/getfile.php?fileid= … 038&menustate=0
I was aware of xusbsupp, but WinUSB is better since it supports USB 2.0 on Windows 95; also, by disabling the drivers for my network card, the freezing has stopped.
Ok see if this build improves for you, may crash, let’s see!
Reply 344 of 347, by Match451
I set up another Windows 98 machine with the V9X remote agent - a P3 with a voodoo5 5500 AGP. I sent you a message on it. It's in the same vlan as the P2 Riva 128 machine. Hopefully they're both working properly. I could swap out the video card if there's something else you'd rather have in it.
Also, it doesn't seem to have caused any problems, but should I remove the Voodoo1 from the P2 Riva 128 machine or does having it in there not affect driver development?
Thanks for all your work on this cool project!
Reply 345 of 347, by mwdmeyer
Match451 wrote on Today, 01:26:
Sick voodoo 5! My vsa100 support is basic but I will test dual chip card. The other machine is perfect, very reliable, I will do more work on it later.
Reply 346 of 347, by myne
You must be burning half a datacenter by yourself 🤣
Did you see my PM btw?
I built:
Reply 347 of 347, by Dothan Burger
How about a Quadro FX 1300 or a PCX 5750? Those have janky 98 drivers. Do I need to message you about the system or is just setting it up and making sure it connects good enough?
