First post, by E|F
I am not sure if these problems are related but I am pretty sure they are.
I have the Orginal Tie Fighter Collectors CD-ROM.
I am running WinXP Pro with a Soundblaster Live! Value.
I have the VDM up to date as far as I can tell.
VDM Sound allows me to run the sounds perfectly however I AM NOT able to run GENERAL MIDI.
I can select General MIDI in the Installer/Sound Set-Up however when I go to test the sound the Installer Locks Up.
However I found I could run the music by using ADLIB.
The problem is that when I am in a mission and a lot of things are going on the sound starts to act really strange. It speeds up and over laps. I can usually correct the problem by hitting ESC and waiting a few seconds however sometimes it just doesn't work. Can anyone help me out?
I have a feeling it would work fine if GENERAL MIDI would work for me but the installer just locks up.
