DOSBox 0.73 Discussion
First post, by Qbix
Rank DOSBox Author
DOSBox Author
Feel free to tell us what you think about it.
Water flows down the stream
Reply 1 of 207, by rcblanke
Great release, a big thankyou and congratulations to the whole team!
Reply 2 of 207, by HunterZ
Congrats! Haven't played with DOSBox much in the last year or two, but I plan to mess with 0.73 when I get a chance.
Reply 3 of 207, by Freddo
Awesome 😎
I really like how it used the swedish keyboard for me by default. But it was also a bit annoying cause I'm so used to use the US keyboard in DOSBox, but I will be used to it soon 😁
I also liked how the disc check in Daggerfall works now. No need to bypass it to play the game. Lovely.
Don't remember if it was an issue in 0.72, but the installer for Dark Forces was wonky in the past, but works nicely now.
Noticed that two issues from 0.72 still remains, Battlespire complain about too little RAM even with memsize=63 (but it works fine) and the sound in some games is still reversed (or did I maybe miss the swap option?)
Anyway, keep up the good work! 😁
Reply 4 of 207, by eL_PuSHeR
Congratulations! 😎
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 207, by bugs_bugger
Great work. My favorite improvement is that the colors in Pinball Fantasies are now 100% right with vgaonly.
Reply 6 of 207, by SKARDAVNELNATE
Good stuff.
Aliens: A Comic Book Adventure installation no longer stalls when Sound Blaster 16 is selected.
Terminator: Skynet detects Future Shock.
Ripper and Elite: Frontier - First Encounters no longer need additional tweaking.
However, I did find that the installer for 7th Guest stalls at Readme.txt. It worked in 0.72.
And that logo screen will take some getting use to.
Reply 7 of 207, by angrylion
Is there an option to turn off the new logo screen?
Reply 9 of 207, by kekko
Congratulations to Qbix, woody, harekiet and all people involved for the amazing job 😀
Reply 10 of 207, by Rightclick
Nice!!! I wished I could just grab an edge, and resize at will.
Reply 11 of 207, by oolie
I definitely gotta check this out:)
Reply 12 of 207, by switchblade
Amazing release and all!
But why does my DOSBox config file refuse to pop up in the DOSBox directory? It's always being outputted to a hidden directory in my "Documents and Settings". How do I fix this?
Thanks.
Reply 13 of 207, by Qbix
Rank DOSBox Author
DOSBox Author
that is intentional in order to make dosbox work nicely on Vista and with more then one user on your system.
Just use the shortcut to edit it and it should be fine
Reply 14 of 207, by MusicallyInspired
If you have a dosbox.conf file in the same directory as the EXE file then it'll automatically use that one instead.
Awesome job, though! Daggerfall seems to run much more smoothly now!
Yamaha FB-01/IMFC SCI tools thread
My Github
Roland SC-55 Music Packs - Duke Nukem 3D, Doom, and more.
Reply 15 of 207, by Qbix
Rank DOSBox Author
DOSBox Author
Well actually the starting directory/cwd, but yes that is right. That is intentional for portable instalations and people who just like having the configfile there.
The "weird" loading is primary for new users. All old ways are still supported.
Reply 16 of 207, by Xerxes
Thank You very much, great release.
Intel C2D E8500@3,6 Ghz, DDR2-800 2x2Gb Ram, MSI Radeon HD6950 Twin Frozr II/OC, Asus P5E Deluxe, Asus Xonar DX, HDD: WD 500AAKS x2, Windows 7 Professional 64bit
Reply 17 of 207, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Also many thanks for all your hard work on my favourite emulator. Congrats on the new release! (though until the end I thought we'd see a version 0.75 😀)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 18 of 207, by hydr0x
It's one of those annoying Vista guidelines. I don't want any config/program files in my user directory, I just want data in there. So it's great you're allowing us to just place an ini in the exe directory. One question though: If I do that before starting DOSBox for the first time, would it still create the ini in my user dir or not? Cause I really don't want it to be there, even if it's not used.
Reply 19 of 207, by DosFreak
You can delete the .conf file from your profile but you'll need to edit the DOSBox shortcuts in the Start Menu to stop the creation of dosbox.conf in your profile.
While your deleting .conf file from your Profile you may also want to delete the hidden "AppData" directory in your profile as well. 😈 Since you just want "data" in there.....
What counts as data to you?
Make your games work offline
