First post, by Unregistered
Hi All,
I'm trying to run an old game that looks brilliant called 'Ascendancy' under Windows 2000.
The game can be found at http://www.the-underdogs.org/game.php?gameid=1525
I have tried using VDMS without success. Apparently the game hangs because of VESA config. Has anyone come across that kind of problem before?
Thanks,
Jean-Michel <jhiver@mkdoc.com>
Reply 1 of 3, by Snover
Tried running NOLFB first?
And, system specs!
Yes, it’s my fault.
Reply 2 of 3, by Unregistered
The way I did it was:
download MOUSE2KV.EXE
place it in the C:\ASCEND directory
make a go.bat file with the line
MOUSE2KV.EXE 640 480 8 8 ASCEND.EXE
in it
launch go.bat and switch to full screen ASAP
then ALT+ESC to close the tip of the day
then full screen again
TADJAAAH! Works. With sound and everything.
Spec: Win2k, GeForce II, Athlon 1600, 512 Mb RAM.
Cheers!
Reply 3 of 3, by Nicht Sehr Gut
Ran fine on mine without any tweaking at all. Mouse wasn't "fast", but it wasn't crippled either...
Of course, I'm working with the original CD...hrmmm...
