First post, by peterrtje
Hello,
I have a problem with installing Theme Park (1994/Bullfrog). I use Dosbox.
When I type the command "install", I become a window for installig Theme Park. But when I go to "install path" and try to change it/ install it, it doesn't work. It says: "you must install from Floppy".
I tried to play the game without installing and type the command: "main" but than nothing happens!!
How can I install Theme Park? Thx!
