First post, by peterrtje
Hello,
I have a problem with installing Theme Park (1994/Bullfrog). I use Dosbox.
When I type the command "install", I become a window for installig Theme Park. But when I go to "install path" and try to change it/ install it, it doesn't work. It says: "you must install from Floppy".
I tried to play the game without installing and type the command: "main" but than nothing happens!!
How can I install Theme Park? Thx!
Reply 1 of 11, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
Since you are(?) installing from a diskette, you must mount a floppy-drive as A instead of a CD-drive as D. Something like this should do it:
mount A "A:\" -t floppy
followed by
A:
install
should do it.
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
Reading the aptly named README file will be a good idea too.
_________________
Reply 2 of 11, by peterrtje
I have burned all of the files on a cd-rom. I never hadfloppys. So I use a cd-rom.
* First I Mount c:
mount c c:\oldgames
* Then I mount my cd-drive:
mount e e:\ -t cdrom
That all works so far. Then I typed:
Z:\>e:
E:\>install
Then I become the window from the Theme Park game for installing it. But I can't install it/change the pat-name. Then it says: "You muss install from floppy".
Then I tried:
E:\>main
But than notihing happens...
Reply 3 of 11, by wd
Rank DOSBox Author
DOSBox Author
Please read what MiniMax wrote.
Reply 4 of 11, by MiniMax
Rank Moderator
Moderator
mount A "E:\" -t floppy
_________________
Reply 5 of 11, by peterrtje
I thank you for your help... 😀 I think, I have the wrong files.. nothing happens 🙁 But thx for you help and your 60seconds guide!!
Reply 6 of 11, by wd
Rank DOSBox Author
DOSBox Author
Did you try what MiniMax posted? You should end up at an a:\> prompt
where you can call install from. Does this result in the same error message?
Reply 7 of 11, by HunterZ
Definitely try what MiniMax suggested in his latest post. It will make the game think your CD-ROM is actually a floppy on drive A:
If that doesn't work then maybe you didn't copy all of the installation files when your made your CD-ROM, or maybe it's looking for a drive label.
Reply 8 of 11, by peterrtje
I've made a new CD. And now it works! 😀 I think, I didn't copy all the files.
Thx for your help!! 😀
Reply 9 of 11, by guilingkwek
hi guys, i'm still having problems installing this game.
ok, first, i got it from [ABANDONWARE LINK REMOVED]
its in 6 floppies in separate folders. i've been trying to mount them but i can only mount disk1. there's no way for me to go back to dos prompt to mount disk 2. neither can i do an imgmount. how do i mount 6 folders into a floppy drive that allows me to switch while the game installer is running?
Reply 10 of 11, by peterferrie
Umm, you mean that you don't own your copy of the game?
And yet you are asking us for help?
This is the wrong place for your question.
Try asking the people at the site where you downloaded it.
Reply 11 of 11, by catchaserguns
We don't support Abandonware here.
