First post, by Darth Geek
OK, I've searched all around VOGONS and other Dosbox forums, but I can't find how to get Descent 2 running.
First of all, I'm using Kubuntu 9.04 with DOSBox 0.72.
I have a Descent 2 folder that I copied from an XP installation in ~/Games/Descent2. In DOSBox, I automatically mount ~/Games/ as the C drive, and mounted /media.cdrom0 (the drive with the descent 2 cd) as D, using "MOUNT D /media/cdrom0 -t cdrom". However, descent 2 does not recognize this as a cdrom drive.
Also, I saw in several places on this and other forums to install from the cd within DOSbox. That doesn't work either: it says install.exe must be run from the cd drive (which... it is.)
I've tried running Descent 2 using WINE but it tries to load the program, then quits with no error message.
Reply 1 of 8, by ripa
Maybe it expects a proper label. Find out the label of the cd and add -label yourlabel to the mount line.
edit: you might need to use the -usecd switch. readme.txt:
3. To mount system CD-ROM drive at mountpoint /media/cdrom as CD-ROM drive D
in DOSBox:
mount d /media/cdrom -t cdrom -usecd 0
Reply 2 of 8, by Darth Geek
Well, I found out how to run d2 without the CD at all- there's a nocd patch:
http://www.jankratochvil.net/project/patchd2/
My problem now is, it tries to load all the movie files (*.mvl) from the cd since I didn't install them with the game. Unfortunately, it can't load them for the same reason I didn't install them: "other-h.mvl" is corrupted beyond repair. My D2 CD has more scratches on it than all my other CDs put together.
Anyone experienced with D2, how do I stop it looking for the movie files on startup? (or at least other-h.mvl, since I have other-l.mvl which contains low-resolution movies)
Reply 3 of 8, by SKARDAVNELNATE
In DESCENT.CFG there is an item MovieHires=1. Change this to MovieHires=0.
Reply 4 of 8, by Darth Geek
Yes! Pure maniacal robot-killing OWNAGE!
It works 😁
Reply 5 of 8, by MONITOR613
rather than start another Descent 2 thread i thought i'd piggyback on this one. my problem is i don't know shit about code and all this is Greek to me . i got the dos box up and running but i get a 'doesn't support fullframe' or something as such. i downloaded the patch that was linked by Darth Geek, but i don't know what to do with it!!
Reply 7 of 8, by MONITOR613
you see! i can't even explain what i need! THIS SUCKS!!!
*btw* your avatar is fucking awesome. is there a high res version somewhere?
Reply 8 of 8, by SKARDAVNELNATE
It's the Altered States goat. A movie from 1980.
What is the full error message and how did you setup your game?
