First post, by bludelfino
Hi all!
Does anybody know if there is any way to run VDMSound in a window other than the full-screen mode?
Thank you for your help, bye!
Hi all!
No.
Yes, it’s my fault.
Originally posted by bludelfino Does anybody know if there is any way to run VDMSound in a window other than the full-screen mode?
Only if the program itself can be run in a window (IOW, only if it stays in text mode). For 99.9% of what's out there, that means "No".
wrote:Only if the program itself can be run in a window (IOW, only if it stays in text mode). For 99.9% of what's out there, that means "No".
For the record, bludelfino, this is a limitation imposed by Windows NT/2000/XP ant not by VDMSound. Whenever a DOS program (like the games you want to play) tries to use a graphic mode, Windows switches the NTVDM to full screen.
Regards,
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
