Run VDMSound in a window
First post, by bludelfino
Hi all!
Does anybody know if there is any way to run VDMSound in a window other than the full-screen mode?
Thank you for your help, bye!
Reply 1 of 3, by Snover
No.
Yes, it’s my fault.
Reply 2 of 3, by Nicht Sehr Gut
Originally posted by bludelfino Does anybody know if there is any way to run VDMSound in a window other than the full-screen mode?
Only if the program itself can be run in a window (IOW, only if it stays in text mode). For 99.9% of what's out there, that means "No".
Reply 3 of 3, by MajorGrubert
For the record, bludelfino, this is a limitation imposed by Windows NT/2000/XP ant not by VDMSound. Whenever a DOS program (like the games you want to play) tries to use a graphic mode, Windows switches the NTVDM to full screen.
Regards,
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
