First post, by AdamP
I asked this on dosgames a few years ago, but I'm no closer to a solution than I was back then, and this has been stumping me for years.
The game hangs the computer when someone fires (usually after I fire) and I sometimes get a continuous buzz (from the music synthesiser I think) or hissing or other noise from the sound card (SB AWE64 Gold CT4540) that doesn't stop until I switch the computer off via the power switch (the only input that works). None of this happens when I disable the digital sound effects. The music setting doesn't affect it. The sound itself works fine, except for some reason it causes the computer to hang, usually without warning. I can't try it in DOS mode because the game hangs as soon as I get to the gameplay.
The game worked fine on an ESS 1869 Audiodrive, but I don't want to have to go back to that and sacrifice wavetable just to get one game working. I was wondering if anyone here can provide some clue as to why Solar Winds doesn't seem to like my AWE64 Gold. My other DOS games work fine with it.
Thanks.
Other specs:
Windows 98 original
64mb 133mhz SDRAM
Matrox Millennium G200 AGP 8mb
Reply 1 of 16, by leileilol
There's also a hard hang with Duke Nukem II on the AWE64 and could also be related and I still don't know what it is. 🙁 Same 1993 era though, maybe something regressed.
Reply 2 of 16, by robertmo
check it in/use DOSBox
Reply 3 of 16, by leileilol
DOSBox on a '98 spec rig you kidding!?
Reply 4 of 16, by robertmo
is that your only pc? 😉
Reply 5 of 16, by HunterZ
I believe they released a slightly newer version of Solar Winds to fix some bugs (v1.1 maybe?), might help in your case.
I beat it a couple times back in the day, and was playing through it again in DOSBox a year or two ago. Had a strange bug where my ship would zoom off to the left at greater-than-hyperspeed if my ship was pointing in a specific direction - made combat almost impossible!
Reply 6 of 16, by SKARDAVNELNATE
My copy is version 2.0 according to the HELPME.DOC file. It has the same problem with flying off without reason. If there is a fix for it I'd like to know where.
Reply 7 of 16, by lightmaster
did you search patches scrolls?
Reply 8 of 16, by HunterZ
I did, and didn't find anything there... I'll see if I can remember to dig around for it.
Reply 9 of 16, by AdamP
According to the game, I have v1.1 but according to the helpme.doc, it's version 2.0.
I would like to see if this also happens in DOS mode, but I cannot because it just hangs as soon as I start the gameplay.
Autoexec.bat:
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
mode con codepage prepare=((850) C:\WINDOWS\COMMAND\ega.cpi)
mode con codepage select=850
keyb uk,,C:\WINDOWS\COMMAND\keyboard.sys
SET SOUND=C:\SB16
Config.sys:
device=C:\windows\himem.sys /testmem:off /cpuclock:off /v
dos=high,umb,auto
device=C:\windows\emm386.exe noems
devicehigh=C:\windows\setver.exe
devicehigh=C:\oak\oakcdrom.sys /D:mscd001
device=C:\WINDOWS\COMMAND\display.sys con=(ega,,1)
Country=044,850,C:\WINDOWS\COMMAND\country.sys
;devicehigh=C:\windows\command\ansi.sys
FILES=45
BUFFERS=30,0
STACKS=9,256
;devicehigh=C:\usbaspi.sys
;devicehigh=C:\di1000dd.sys
Dosstart.bat:
C:\WINDOWS\CTCM
lh C:\mouse\mouse
lh C:\windows\command\MSCDEX.EXE /S /D:mscd001
lh C:\sb16\aweutil /em:GM /key-
C:\sb16\ct3dse on
I think I tried it on dosbox on this pc ages ago, and I couldn't reproduce the problem, but it didn't run anwehre near as smoothly.
Of course not, I wouldn't be using the internet on a 12-year-old pc. I'm just curious as to why it doesn't work on a pc it should be working fine on.
Reply 10 of 16, by aleksej
Turn off GM emulation by disabling this string (replace it with "aweutil /s" command) and check again.
Reply 11 of 16, by HunterZ
Maybe the game expects the sound blaster to be on IRQ7 instead of IRQ5?
Reply 12 of 16, by AdamP
I've tried setting the card to different combinations of resources in Windows, but none of them fixed the problem, and in some cases, created other problems. When I had the I/O set to 240, the game wouldn't initialise the sound card, and when I had the DMA set to 3, the game crashed with an invalid instruction error when it tried to play a sound (but it didn't hang the system). It worked fine on DMA 1 (apart from the hanging). Whether the IRQ is 5 or 7 doesn't seem to make any difference.
I still cannot run it in DOS mode. I tried disabling general midi emulation, but it still hangs when I get to the gameplay (but I thought Solar Winds doesn't use general midi).
Reply 13 of 16, by HunterZ
Nope, Solar Winds just uses Adlib OPL2 FM synthesis music.
Reply 14 of 16, by AdamP
Adlib? The helpme.doc says it doesn't support Adlib and requires Sound Blaster.
When I have the low DMA set to 3, the game doesn't initialise the sound card (the other problem with DMA 3 was when that was the only DMA channel). Because the sound seems to work on some DMA configurations and not others, the hanging problem may be DMA-related (DMA is the usual cause for this type of problem), but I have no DMA conflicts. I have no idea why the game doesn't seem to work on other DMA chanels.
Perhaps the game simply doesn't work properly with this sound card?
Reply 15 of 16, by HunterZ
It might be that it only supports Sound Blaster because it also uses the SB DAC for digital sound effects.
Why are you using a SET BLASTER= line with D1 if the card is on DMA 3? 😕
Reply 16 of 16, by AdamP
I set the card back to DMA 1 afterwards.
Now I think about it, pointing the finger at the sound card may have been a bit premature. I haven't tried playing the game with this card on any other system so it could be that there's some issue between the motherboard or chipset and this sound card (but I don't think so as no other game I have has this kind of problem).
Or there could be some problem with its Sound Blaster compatibility (it's supposed to be fully Sound Blaster compatible)?
