First post, by Love the classics
Been running 0.72 for years on an XP machine, worked great. Just built a new system running Win 7, 64 bit. Did some research and found I'd need 0.73 for Win 7. Downloaded it, setup my config, mounted C:, CD Drive etc, launched one of several old DOS games I had and everything looked fine except.... and this goes for everyone of the 14 programs I have in my CDrive directory; about 1-2 minutes after launch of any of these programs, the video corrupts(?) and looks to drop into a 16 color?, EGA? mode?
I've used every video emulation available in the config file to no avail. Hoping someone has some ideas.
System:
Intel I7 processor @ 2.66
Gigabyte MB GA-X58A-UD3R
Ram 6 gig Corsair
Video Sapphire 4870 1 gig VRAM
BTW I have the newest drivers loaded for everything. Sytem was just built about a month ago.
Many thanks to any respondants.
Reply 1 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
kill explorer.exe 😉
anyway wait for 0.74
win7 their explorer corrupts the palete
Water flows down the stream
Reply 2 of 10, by robertmo
try different output=
Reply 3 of 10, by Love the classics
kill explorer.exe
So how would I do that? Is there even a way? And is a 0.74 under development?
Reply 4 of 10, by Love the classics
I've tried that... started with surface, currently ddraw, tried opengl etc. nothing worked. Apparently explorer corrupts the pallete.
Anyone running in Win 7 64bit with success?
Reply 5 of 10, by DosFreak
Final option is to set the SDL_VIDEODRIVER=WINDIB variable.
Either that in your System Variables or create a batch file as follows:
set sdl_videodriver=windib
dosbox.exe
Make your games work offline
Reply 6 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Is the pope catholic?
Seriously, Dosbox is always under heavy development and yes, a 0.74 is under development and doesn'T seem like toooooo far off 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 10, by Love the classics
Well, tried setting the SDL_VIDEODRIVER=WINDIB variable.. no luck.
Guess my only option is to wait for 0.74 😒
At least I can still play around on my old XP machine 😉
Thanks for all the responses guys.
Regards,
Gary
Reply 8 of 10, by lightmaster
last resort, try a svn build.
Reply 9 of 10, by leileilol
Change output= in the .conf file, not during the run of the emulator. Opengl shouldn't ever use a screen palette or 8-bit color (which Windows 7 will definitely screw).
No, I don't have Windows 7, I don't even know why i'm posting! The good samaritan in me wants me to!
Reply 10 of 10, by robertmo
type
output
inside dosbox and tell us what it replies
