Reply 40 of 54, by Mau1wurf1977
aitotat wrote:
3Dbench v1.0 results
Clock | ISA | VLB
25 MHz : 9.8 FPS | 11.4 FPS
33 MHz : 13.1 FPS | 15.3 FPS
40 MHz : 15.8 FPS | 18.5 FPS
Thank you so much!!! 😀
13.1 for a DX-33 was exactly what I estimated. Very good to know... Looks like my table is pretty accurate with the estimated "net speed results".
Regarding ISA vs. VLB (I still can't believe you have a 386 with VLB that's awesome...)
The improvement is actually quite impressive. We are talking around 17% better performance! Just shows that ISA was holding back the 386DX by quite a bit...
Reply 41 of 54, by Tetrium
Will 3DBENCH run from a standard DOS bootdisk?
If not, will it run in Windows or the DOS that's installed with Windows?
Reply 42 of 54, by Mau1wurf1977
Yes it will!
I tried a W98SE boot disk and also one made in W7.
Reply 43 of 54, by aitotat
True! I guess I'm so used to modern FPS readings that less than 3 FPS feels like something that could fit in a margin of error.
I'm not even sure anymore that the S3 864 is faster at all. S3 864 has 64-bit internal bus but standard VGA cannot benefit from it. VESA VBE functions and Windows (with proper drivers) would definitely benefit from it but not plain VGA.
My youtube channel
Reply 44 of 54, by Tetrium
Yes it will!
Cheers! Will try my 486 DX4-100 maybe tonight even 😀
Reply 45 of 54, by keropi
wow... just tried 3Dbench with my p200mmx and I get 49.2 ..???!?!?! way too low and the machine is fast in games like Blood @1024*768 ... maybe some petium conflict? the benchmark completes in ~2 secs btw...
Reply 46 of 54, by Amigaz
keropi wrote:
np, if I get a util that can display the extra info I will post here... the IBM bios displays only memory count on startup, no h […]
np, if I get a util that can display the extra info I will post here... the IBM bios displays only memory count on startup, no hardware config whatsoever... Also the bios is limited to the extreme basics too and you use a boot-disk to enter it... typical brand-name bios on the era 😁
here is the machine (2123 pro PS1 model)
Finally I get to see some pics of this greek, mythical beast! 😁
Reply 47 of 54, by Amigaz
Ok, I've done a marathon testing now 😜
Commodore 386C-33
CPU: AMD 386DX 33mhz
Mainboard: Unknown Synphony chipset
Amount of RAM: 8
Amount of L2 Cache: 64k
Video card: Ati Mach32 DRAM ISA 2mb
3dbench score: 12.6
Asus pimped to max, mini AT tower
CPU: Intel 386DX 33mhz
Mainboard: Asus ISA-386C
Amount of RAM: 8mb
Video card: Diamond Tseng ET4000 1mb ISA
3dbench score: 13.3
Commodore PC-50 II
CPU: Intel 386SX 16 mhz
Mainboard: Commodore unknown model/chipset
Amount of RAM: 5mb
Amount of L2 Cache: n/a
Video card: Tseng ET4000 1mb ISA
3dbench score: 5.0
Full AT fully pimped out eisa 486 machine
CPU: Evergreen am5x86 133mhz
Mainboard: Everex Step VL/e
Amount of RAM: 32mb
Amount of L2 Cache: 256k
Video card: Ati Mach32 VLB 2mb DRAM
3dbench score: 71.4
Another Full AT fully pimped out eisa 486 machine
Mainboard: Gigabyte GA-486TA
Amount of RAM: 20mb
Video card: Diamond Stealth 64 DRAM VLB 2mb
3dbench score: 76.4
Reply 48 of 54, by Mau1wurf1977
Very nice!
I will revisit the Slot 1 system for my project and use your data. I now have a much better idea of what tests I need to run to show some scaling.
The FSB scaling approach I used on the SS7 system is much better and needs a lot less tests.
Watch the space!
Reply 49 of 54, by Amigaz
Mau1wurf1977 wrote:
Very nice! […]
Very nice!
Watch the space!
Glad I can help 😀
If you also need a Cx 5x86 system result please let me know...or from a very early 486 system with a 25mhz 486 😉
Reply 51 of 54, by Mau1wurf1977
Sorry just now saw your post!
This is because version 1.0 doesn't work well on Pentium and faster. Version 1.0c should be used on Pentiums and faster.
However 1.0c has issues on really slow machines (results are way to high)...
I am working on a nice sheet and will get a 3dbench database going! It should be good. I am currently entering all the data from this thread and then we can go nuts with benching!
Watch the space!
Reply 52 of 54, by Mau1wurf1977
Any new results please go to the new "3DBENCH CPU Benchmark Database" thread:
Reply 53 of 54, by Amigaz
A couple of more 486 benchmarks:
AMD-5x86-33-4-133-Compaq-kein anung-Compaq-256k-EISA-Elsa Winner 1000 S3 928 MX440-2MB-Defaults-Amigaz-62.5
Cyrix-5x86-33-3-100-Asus-PVI-486SP3-SiS 496-256k-PCI-S3 Virge GX-4MB-Defaults-Amigaz-66.6
The above system is a screamer but get's spanked by my VLB systems because of the poor PCI chipset
Reply 54 of 54, by Fenyo
I've 2 old retro 486 machine, here's the results:
1.QDI v4p895p3 smt v5.0 mobo (opti895 chipset), am5x86-P75 at 150 (3x50), 256kb L2 cache, 16 mb ram (2x8 edo at fpm mode), Diamond Stealth 64 Vram (S3 964 Chipset) 2Mb Vlb, Ms-Dos 7.1 (win95osr2); 90.9 fps
2. Dataexpert Exp4044 256kb l2 cache(opti895 chipset too, but doesn't support write back cache and L2 cache instable 40 and 50 Mhz fsb, so i stuck at 33Mhz), am486dx2-66@100 (8kb write trough l1 cache, 3x33 strange dx2 doesn't work 2x multi, maybe the mobo's bios bug), 16 mb fpm ram, S3 805p 1 Mb vlb, Ms-Dos 6.22; 66.6 fps
