Reply 20 of 1046, by leileilol
- l33t++
Debian's fucked
Debian's fucked
After my post there was a 0.41a release
BTW can anyone verify the accuracy of the speed of the 486SX 40MHz emulation? I had a crappy ISA video card back then so I don't really know, I don't remember Doom running that fast on 40mhz.
Debian's fucked
Run 3dbench (1.0) which you can find attached at the start of the 3dbench database thread!
I get 21.2 with 486 40MHz, which matches 5u3's 486 40MHz result. So YES!
Debian's fucked
Excellent!
PS: I knew that database would come in handy one day 🤣
That's the kind of thing I was hoping people would use this database for...
Am I allowed to plug my own release? PCem v0.5 is out, with lots of fixes and new features and stuff.
Hi SarahWalker, Can one use any Bios or does the emu check the crc?
I've been wondering where I'll find the bios for each system.
Googling didn't help for 386/486 😜.
Is it illegal to distribute one?
Go back to the PCem page. Then scroll down.
Alright, thanks 😀
I'll give it a try as soon as I have some more free time!
"- On some Windows 7 machines some keys won't work. I've heard this might be down to a buggy infrared driver. A
workaround has been added - in the settings menu, you can switch from the Allegro keyboard handler to Windows.
This has some other sideeffects, so don't use it unless you need to."
It's actually the eHome MCIR keyboard drivers that seem to be persistently annoying - it affects SDL bigtime, too. Uninstalling them fixes the key bug but it'll also come back after a reboot
either way, you can't seem to press the ` or ~ key in pcem, so you can not mighty foot in duke3d
Wish the SB freq is changable to 49716hz or something. opl on 22khz is a bit grating
the window resizing is GREAT, btw.
Debian's fucked
V0.6 now out. Windows 95 now works, along with 3.x enhanced mode, there's FPU emulation (Quake, Quake 2, Screamer Rally, Tomb Raider etc now work), bugfixes, and a load of other stuff.
wrote:Wish the SB freq is changable to 49716hz or something. opl on 22khz is a bit grating
Quick question, why is such a frequency used for the SB?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
adlib
I mean, is it the native output of the device? Just seems a bit odd after putting up with common sample rates for so long. (11,025, 22,050, 44,100, 48,000, etc.)
Sorry for hijacking the thread 😒
my website
Yes, that's the output sampling rate of OPL2/OPL3. Obviously no modern system supports this sampling rate so PCem uses 48kHz instead. Not sure where the above mentioned 22kHz come from.
AM5x86-133 and WinBIOS EMULATION 😳
THANK YOU!
Debian's fucked
wrote:Yes, that's the output sampling rate of OPL2/OPL3. Obviously no modern system supports this sampling rate so PCem uses 48kHz instead. Not sure where the above mentioned 22kHz come from.
Most sound cards nowadays support any sampling rate from about 8 to 96KHz. So there's no problem in using 49716Hz.
Does anyone actually care if the sample rate is ~3.6% off? You're never going to notice it.
