PCEm. Another PC emulator.
Reply 20 of 1046, by leileilol
Yes
Reply 21 of 1046, by leileilol
After my post there was a 0.41a release
BTW can anyone verify the accuracy of the speed of the 486SX 40MHz emulation? I had a crappy ISA video card back then so I don't really know, I don't remember Doom running that fast on 40mhz.
Reply 23 of 1046, by leileilol
I get 21.2 with 486 40MHz, which matches 5u3's 486 40MHz result. So YES!
Reply 25 of 1046, by SarahWalker
Am I allowed to plug my own release? PCem v0.5 is out, with lots of fixes and new features and stuff.
Reply 26 of 1046, by telanus
Hi SarahWalker, Can one use any Bios or does the emu check the crc?
Reply 27 of 1046, by F2bnp
I've been wondering where I'll find the bios for each system.
Googling didn't help for 386/486 😜.
Is it illegal to distribute one?
Reply 28 of 1046, by SarahWalker
Go back to the PCem page. Then scroll down.
Reply 29 of 1046, by F2bnp
Alright, thanks 😀
I'll give it a try as soon as I have some more free time!
Reply 30 of 1046, by leileilol
"- On some Windows 7 machines some keys won't work. I've heard this might be down to a buggy infrared driver. A
workaround has been added - in the settings menu, you can switch from the Allegro keyboard handler to Windows.
This has some other sideeffects, so don't use it unless you need to."
It's actually the eHome MCIR keyboard drivers that seem to be persistently annoying - it affects SDL bigtime, too. Uninstalling them fixes the key bug but it'll also come back after a reboot
either way, you can't seem to press the ` or ~ key in pcem, so you can not mighty foot in duke3d
Wish the SB freq is changable to 49716hz or something. opl on 22khz is a bit grating
the window resizing is GREAT, btw.
Reply 31 of 1046, by SarahWalker
V0.6 now out. Windows 95 now works, along with 3.x enhanced mode, there's FPU emulation (Quake, Quake 2, Screamer Rally, Tomb Raider etc now work), bugfixes, and a load of other stuff.
Reply 32 of 1046, by franpa
Quick question, why is such a frequency used for the SB?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 33 of 1046, by wd
Rank DOSBox Author
DOSBox Author
adlib
Reply 34 of 1046, by franpa
I mean, is it the native output of the device? Just seems a bit odd after putting up with common sample rates for so long. (11,025, 22,050, 44,100, 48,000, etc.)
Sorry for hijacking the thread 😒
my website
Reply 35 of 1046, by SarahWalker
Yes, that's the output sampling rate of OPL2/OPL3. Obviously no modern system supports this sampling rate so PCem uses 48kHz instead. Not sure where the above mentioned 22kHz come from.
Reply 36 of 1046, by leileilol
AM5x86-133 and WinBIOS EMULATION 😳
THANK YOU!
Reply 37 of 1046, by jwt27
Most sound cards nowadays support any sampling rate from about 8 to 96KHz. So there's no problem in using 49716Hz.
Reply 38 of 1046, by VileR
Cards yes, but those internal sound devices that come with almost all dekstops and laptops are a different matter.
Reply 39 of 1046, by SarahWalker
Does anyone actually care if the sample rate is ~3.6% off? You're never going to notice it.
