First post, by gonzman
Hello everyone,
After a brief search of the forums i got RoAk 2 to work decent with a few problems i will mention later., the mouse problem with fixed with the new .exe mentioned in a thread.
Anyway, is there a same fix for Blade of Destiny, because i can't get the mouse to work in that one either 😐
*** EDIT***
I should mention i can get RoAK1 to work in DOSBOX, but the frame rate refreshes very slowly, e.g, i could be getting 9999fps, but the screen draws it slowly, looks like theres lines running down the screen every time i move a square in any direction.
And if i speed up DOSBOX to a level where i don't get this anymore, the sound screws up.
And theres a permanant problem with movement, everytime i press a key to move my party up a square theres about a 1/2 second delay, the more i press a key the more the delay increases.
*** EDIT ***
About a few problems i have been having with RoAk 2,
While it's running, i get sound, perfect, but no music? what is the best settings to get music in the game, im running the new beta of VDM sound by the way.
And there's a graphic problem and a speed problem.
Randomly during battles the screen will go all garbled and remove all sprites from the screen so all i can see are the tiles on the ground, any fix for this?
Plus, what's a good program to slow down the speed of the game, because during travel map the game runs so fast i can't see where im going.
And during battles, everything moves fine, but when an attack is being done it runs so fast i can't see the animation or the little bubbles that pop up to show how much damage was done.
Thanks for any ideas.
- gonzman
