Reply 20 of 111, by mOBSCENE
wrote:Would you mind running 3DMark99max with the Voodoo2 again in 640 and 1024 and postig the results?
Just gave it a shot: results are almost identical for all three resolutions. So the CPU is unable to keep up with the V2's, which is not a really big surprise ofcourse 😀 I might try Quake2 later on. I've never heard of Daikatana before, but I'll check it out.
wrote:I think your mobo supports all 8 Super 7 multi's
Sounds tempting... 🙄 I'm not really familair with CPU's and overclocking on Socket7 boards. The mobo manual doesn't speak of any multiplier higher than 4.5x, but the guy here http://k6plus.com/index.php?name=PNphpBB2&fil … iewtopic&t=1758 is using a 6x multiplier with this board?! Also, how would I know what voltage settings to use or find out the fastest multiplier / CPU speed support?
I noticed the K6-2 CPU's are really easy to find, so I might actually consider that, if it's not too risky. I've attached the manual of my mobo, maybe someone would like to take a look and me help me out a bit? 😊
wrote:I had a thread about it posted years ago.
Looking nice! I really don't understand how you managed to resize the icons. The manual states it's only possible for icons without border - "what?!" I can't find such icons in QuikMenu.
