First post, by RN
I am using Windows 7 32 bit Ultimate and trying to use a legacy dos application of Lotus 1-2-3 v3.4 or v4. I have tried using an XP video driver, but it still doesn't work properly so I thought I would try dosbox. Problem here is, the lotus application will get to the splash screen and then it stops and doesn't progress forward to the actual spreadsheet.
Anyone else have success getting Lotus v3.4 or v4 working using dosbox?
Thanks
Randy
