Reply 20 of 24, by Chaniyth
- Member
wrote:Are you sure? Perhaps you started reading http://www.freedos.org/freedos/news/technote/200.html but did not scroll down to the […]
wrote:Update: Okay, so Windows 3.11 does NOT run on FreeDOS whatsoever, ugh. 😢
Are you sure? Perhaps you started reading http://www.freedos.org/freedos/news/technote/200.html but did not scroll down to the Update at the very bottom? (The FreeDOS documentation leaves much to be desired. See also http://www.freedos.org/freedos/news/newsitem/166.html .)
are there any Long File Name extensions for MS-DOS 6.22?
I think so, but I'm not sure why you would want to use them if you don't actually have Win9x installed. There's a lot that can go wrong.
Yeah i'm sure, it gripes about a C:\DOS\BIN\LFNXAT.386 file not being found or something like that amongst other weird errors where it can't find display.drv or anything like that, im re-installing FreeDOS one lasttime and if it don't work again then i'm just gonna say f**k it, and "go back" to either my original MS-DOS 6.22 + Windows 3.11 WFWG configuration or just install crappy Windows 98 SE but install it using the 98 Lite modification, 98 micro .
