Trying to find out about a particular AWE32
Reply 20 of 29, by leileilol
Here's some Solar Winds OPL3age
http://www.youtube.com/watch?v=8yQGtFH9qZM
The music was played back through a SBPro PLAYCMF
There are some unfortunate recording skips.
Good luck comparing!
Reply 21 of 29, by Mau1wurf1977
Jorpho wrote:
It's also been a while, so I have no idea what sort of drivers this thing needs. Will http://www.vogonsdrivers.com/getfile.php?fileid=51 be enough?
To quickly get a card going (without installing anything onto the system) run CTCM (the Creative Plug and Play program) and then AWEUTIL /S.
The card should now be up and running.
Reply 22 of 29, by Jorpho
That's it? It thought you needed CTCU as well.
Reply 23 of 29, by Mau1wurf1977
Only if you want to change the resources that CTCM picks for you. CTCU is in the same folder as CTCM anyway though 😀
Reply 24 of 29, by Jorpho
Curses, the Panasonic DOS USB driver doesn't seem to like the USB controller on my ASUS P3B-F. That's going to make things a little more complicated.
Reply 25 of 29, by Jorpho
All right, that ought to do it. MI2 on the CT3670 and, for good measure, the CT3600.
Reply 26 of 29, by Mau1wurf1977
Both sound like OPL3 to me.
EDIT:
Amazed at the clean recording. My Sound Blaster cards are very loud in comparison...
Reply 27 of 29, by gerwin
CT3670 has an AWE64 chipset, but with 30-Pin memory slots.
CT3600 has the vibra 16 pro CT2502: the best output quality of the whole SB16/32 line AFAIK.
Both cards have CQM.
Reply 28 of 29, by AdamP
Phew! I was afraid I had seriously misled the OP, but it seems like I haven't 😀.
Reply 29 of 29, by Jorpho
Since I had everything set up, I thought I'd give it a whirl on my SB Live (sb0100, using sbeinit.com).
While adjusting the volume, I noticed that sbemixer.exe had a checkbox labelled "MT32", so I tried the recording with that marked as well... I don't think it made any difference, though.
Did I mess up somewhere? There's got to be a way to make it work better than this. 😒
