Well thanks for all the suggestions. I shut down the computer last night and when I restarted this morning the CYBORG was in the Control panel/games controller section. I don't often shut down for other reasons BUT the Cyborg worked OK on Xwing vs TIE fighter OK before I shut down.
So the lesson here is, REGARDSLESS of the what it is that is we installed it's a damned good idea to reboot after the installation. The old rules still apply.
The DOSbox config shows both joysticks. Not that it is need but I'm leaving the both there to see what happens. I'll running this trial with XWING Collector's Edition.
Will report outcome for completeness.
Wish me luck "and may the force be with you 😉 "
