First post, by ProfessorProfessorson
- Member
System used listed here:
Rage Fury MAXX Slot A build
This is going to be a slow WIP list, and I will simply update it as I get the time to play stuff on the system. My criteria for a game making a passing grade is being able to run without bugs and issues, unless the bug or issue is totally unrelated to the card and happens on all graphics cards, AND to run the game at least on high settings and 800x600 resolution and obtain smooth gameplay (some games I may run may only allow 640x480 res settings, like Raystorm). V-sync is disabled on the card by default for both Open GL and Direct X.
Quake 2 (Passed)
Quake 3 (Passed in single GPU mode, stuttered badly in dual GPU mode)
Dethkarz (Failed, game crashes at startup intro video in either GPU mode)
Raystorm (Passed)
Need For Speed 3 (Passed)
Need for Speed: Porsche Unleashed (Passed)
Resident Evil 3 (Passed)
Star Wars Episode 1 Racer (Passed)
Le Mans 24 Hours (Passed)
Master Rally (visually fine, framerate when multiple vehicles present is too low to play game)
HyrdoThunder (Passed)
Heavy Gear 2 (Passed)
Unreal Tournament GOTY (Passed in 16-bit color, high details. Framerate was between 40-70 most matches. Dipped to low 30fps on a couple of the massive area matches. 32-bit color caused frame stuttering issues in either single or dual gpu mode)
