Aideka wrote:You can back up your save files, they should be on your daggerfall directory and named Save0, Save1 and so on I think. Then just copy those folders to your new installation.
EDIT: Just to clarify, the saves should be on folders, copy those folders to your new installation. If there are no such folders, then wait for someone else to come along and help, since I have not played daggerfall myself and just found this on google.
Right - I've downloaded and installed from Bethesda and managed to get Daggerfall to run in Dosbox.
- I then copied all the files from my existing save game to the Dagger directory.
- Tried loading the game from the old save file and the game exits and provides a message stating "Invalid save game format"
- Therefore, I downloaded patch fixsa175 again from here http://www.uesp.net/wiki/Daggerfall:Files which apparently resolves the save game problem I'm having.
- I've opened dosbox and mounted the c:games etc.. folder
- HOWEVER: When selecting the exe file for the update I'm asked to insert the original Daggerfall cd to continue => which I obviously don't have.
Any ideas on how I can run this update through Dosbox without having to start my game from scratch?
Thanks,
Rob
