First post, by silentwulf
I'm having a few issues getting Toonstruck to run on a legitimate 486 machine. Only issue I'm having is when I try and run the game. I get this error;
Could Not Configure Linear Access To Video Memory
Game Will Play Slow.
Continue? (Y/N)
I have a Cirrus Logic GD5424 (VESA). During setup, it displays the test image at 640x400 without a problem. And as the error suggests, when I do run the game, it just crawls. Any suggestions?
Reply 1 of 11, by PowerPie5000
What 486 are you running it on? I think a 66MHz 486 is the minimum for this game (and it'll probably run slowly). I used to play it on a 75MHz Pentium with 2MB S3 Trio graphics and never had any issues.
Maybe it's a hardware limitation for that particular Cirrus chip?
Reply 4 of 11, by PowerPie5000
silentwulf wrote:
It's a 66MHz 486. I do load UVConfig, and it detects the card.
It will run slow with the games minimum requirements. They recommend a Pentium class CPU along with 16MB RAM... It ran better on my old 75MHz Pentium than it did on a 100MHz 486 if that's anything to go by.
Reply 5 of 11, by leileilol
For SVGA point-and-click adventure games a 486 should do fine with enough video throughput, especially PCI. You should even be able to play Star Control 3 (*shudder*) on one of those, if you can put up with watching the pages flip.
Reply 8 of 11, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Not related to config.sys.
So the game comes with univbe? What's the version? Is there a univbe.exe?
I've attached the output of uvconfig when a linear framebuffer is available. Does yours mention the LFB?
    4.53 KiB
1+1=10
Reply 9 of 11, by silentwulf
This is what I get after running UVCONFIG, which seems to be the same as univbe.exe (which doesn't exist on the disc)
    172.05 KiB
Reply 10 of 11, by PowerPie5000
Looks like it's not finishing/updating or applying VBE 2.0 as there's no confirmation. Maybe try a different version?
