First post, by silentwulf
I'm having a few issues getting Toonstruck to run on a legitimate 486 machine. Only issue I'm having is when I try and run the game. I get this error;
Could Not Configure Linear Access To Video Memory
Game Will Play Slow.
Continue? (Y/N)
I have a Cirrus Logic GD5424 (VESA). During setup, it displays the test image at 640x400 without a problem. And as the error suggests, when I do run the game, it just crawls. Any suggestions?
Reply 1 of 11, by PowerPie5000
What 486 are you running it on? I think a 66MHz 486 is the minimum for this game (and it'll probably run slowly). I used to play it on a 75MHz Pentium with 2MB S3 Trio graphics and never had any issues.
Maybe it's a hardware limitation for that particular Cirrus chip?
Reply 2 of 11, by leileilol
Did you try loading UniVBE?
Debian's fucked
Reply 3 of 11, by silentwulf
It's a 66MHz 486. I do load UVConfig, and it detects the card.
Reply 4 of 11, by PowerPie5000
It will run slow with the games minimum requirements. They recommend a Pentium class CPU along with 16MB RAM... It ran better on my old 75MHz Pentium than it did on a 100MHz 486 if that's anything to go by.
Reply 5 of 11, by leileilol
For SVGA point-and-click adventure games a 486 should do fine with enough video throughput, especially PCI. You should even be able to play Star Control 3 (*shudder*) on one of those, if you can put up with watching the pages flip.
Debian's fucked
Reply 6 of 11, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
> I do load UVConfig
Did you load univbe itself?
1+1=10
Reply 7 of 11, by silentwulf
If I'm not mistaken, I load the DRV file in the Toonstruck directory via Config.sys?
I.E. Device=
Reply 8 of 11, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Not related to config.sys.
So the game comes with univbe? What's the version? Is there a univbe.exe?
I've attached the output of uvconfig when a linear framebuffer is available. Does yours mention the LFB?
1+1=10
Reply 9 of 11, by silentwulf
This is what I get after running UVCONFIG, which seems to be the same as univbe.exe (which doesn't exist on the disc)
Reply 10 of 11, by PowerPie5000
Looks like it's not finishing/updating or applying VBE 2.0 as there's no confirmation. Maybe try a different version?
Reply 11 of 11, by silentwulf
Where's a good spot to find a better version? Found a few older ones online.
