First post, by mkvreak
Hello!
I just downloaded the newest DOSBox SVN Daum build and was reported an error message “Set /P is not supported. Use Choice!”
The source code tells me that there is just another if expression that checks for /p in the set command, no comment or explanation. So why is this done?
An explanation why I think this is a bug: I usually put a line “set dircmd=/p/w” in the autoexec section in dosbox.conf, so that “dir” automatically lists directories with /p parameter set (and /w for wide format).
The added query in r3825 does not check if /p is just a string to be added to the variable dircmd instead of /p as a set command parameter, so this breaks the functionality of set command. 🙁
If I’m posting this bug on a wrong place, feel free to correct me. I found a DOSBox bugtracker, but it seems it’s only for the released versions.
Reply 1 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I *think* this was added because people tried to use set /p even though real dos didn't support that. Only the Windows command line did that. And to not have to deal with the recurring "why does set /p not work" the devs added the reply that you should use choice.
This is just how I think it is not entirely sure.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 9, by mkvreak
Ok, that explains the intention. This is fine with me, I don’t need the /p option. But the implementation is kind of, how do I say it politely … unfortunate. It breaks the main function of set because it’s not transparent. I cannot assign any string to a variable that contains “/p”.
Normally I would comment the two lines and compile, but I want to use SVN Daum version, and I don’t know where the repository is hosted and what prerequisites I need. So this better be fixed in the standard DOSbox SVN repository.
Where do I have to report this bug to get this done?
Reply 7 of 9, by mkvreak
Thanks. I see I had the correct bugtracker found, but I didn’t saw the milestone SVN in the list. So, bug is filed, now wait and see. 😀
Reply 8 of 9, by VileR
Workaround for now:
set dircmd=/wp
