486 from the dumpster
First post, by Half-Saint
Two weeks ago I rescued a 486 from the dumpster.
It's a 486DX4/100, motherboard is Shuttle HOT-433 with 256K of cache, video is ATI 3D charger PCI. It had 32MB of RAM but I upgraded that to 96MB just because I could 😁
The hard drive is toast. Dead as a brick. Replaced it with a 200MB WD which mostly boots fine but sometimes takes a long time to start spin-up. Should be getting a few DOMs next month.
There's also a CD-ROM and a 3.5" floppy... nothing special.
Any ideas for further upgrades?
Cheers
Reply 1 of 31, by rgart
that's an excellent find!!
Im a big fan of the DX4-100 chip. Is it an intel overdrive?
You didn't mention a sound card?
Upgrade would be a Roland MPU401 + Roland SC-55 + SB16:)
200MB hard disk? ...How about a 1GB at least.
=My Cyrix 5x86 systems : 120MHz vs 133MHz=. =My 486DX2-66MHz=
Reply 2 of 31, by Half-Saint
It came with a generic sound card which I'm going to throw away. I have two Sound Blaster Live! cards in the stash but that doesn't feel right 😀
Here's a couple of photos:
Reply 3 of 31, by keropi
excellent find! and that BIOS is nice to have, a welcome change from the stock AMIBIOS 😀
The live! won't be good in such a machine, tbh it needs and ISA sound card, not a PCI one
Reply 4 of 31, by Half-Saint
rgart wrote:
that's an excellent find!! […]
I'm not sure about the chip.. would have to look under the heatsink but I'm feeling a bit lazy at the moment 😁
I never really understood what Roland was all about. I always assumed those were just your regular ISA sound cards.. what's the big deal? 😀
Reply 5 of 31, by rgart
if the heat-sink is removable it can't be an overdrive chip.
nice case you have....it just requires a badge 😀
having a Roland MT-32 or Roland Sound Canvas SC-55 ...is like having a mini orchestra in your computer room.
I don't believe any sound card can compare to them.
https://www.youtube.com/watch?v=316i0uV32WE
https://www.youtube.com/watch?v=VN_uvF0XM5g
if those vid's dont impress you I cant help 😜
Reply 6 of 31, by Half-Saint
Yes, I'm working on a custom case badge 😉 Might take a while tho..
Let me get this straight. You connect SC-55 to the SB16 and MPU401 connects to SC-55?
The music from Doom didn't really impress me but I guess that's mainly the composer's fault 😉
Reply 7 of 31, by Jolaes76
No.
There are two routes:
1) Purist soul, heavy purse
You put the MPU-401 card in an ISA slot, then connect its external breakout box. (Each MPU-401 card has its proprietary breakout box. Make sure you get BOTH.) The box will have one or two standard DIN OUTs, there you hook the MIDI brains (MT-32, SC55 etc.) MPU-IPC-T , S-MPU/AT, MPU-401AT kits are recommended.
2) Just to feel the good vibes along memory lane
You buy an external MIDI/joystick port splitter (to joystick and DIN) for the Sound Blaster or other MPU 401 compatible card and connect the SC-55 or other MIDI brain to the splitter's DIN. And you shall use SoftMPU on that Blaster. 😀
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 8 of 31, by Half-Saint
Jolaes76 wrote:
No. There are two routes: […]
No.
Wow these things are expensive! Somebody is selling an MT-32 locally for 70€. Might get it..
Reply 9 of 31, by MaxWar
Care to show us a picture of the card? Some generic cards can actually be pretty good!
Anyway, nice find! DX4/100 are not the easiest to find.
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
Reply 10 of 31, by Half-Saint
Sure, here it is:
Reply 11 of 31, by Jolaes76
...not a keeper.
See opinions on this card here:
A pile of new soundcards for my 486.
Reply 12 of 31, by Half-Saint
Found an OPTi 82C930A in storage. Would it, by any chance, be usable with Roland stuff?
There's a Wave Table header on board. What is it for?
Reply 13 of 31, by MaxWar
Likely yes, but Typically you would connect roland stuff with the joystick port as they are external modules.
Wave table header is to connect internal wave table expansion board, like the popular NEC XR385.
Your crystal Card also looks like it has GM compatibility.
Also, take ACE with a grain of salt he is ultra picky about authenticity and will typically dislike whatever is not a yamaha chip.
I think some crystal clones are not as bad as others, im not sure about this one though.
Reply 14 of 31, by Half-Saint
OK so basically I could use any MPU-401 compatible card, connect an MT-32 via joystick/MIDI port and I'm ready to rock or is there more to it? Maybe it's time to open a new topic 😁
Reply 15 of 31, by MaxWar
basically, but be aware of the so called MPU-401 intelligent mode, which none but the original and a few MPU-401 clones can achieve.
This special mode is requiered by some games for MT-32 compatibility.
Sound blasters and SB clones are not compatible with the intelligent mode.
Reply 16 of 31, by Jolaes76
I can but repeat myself, that is what SoftMPU is for 😀
Reply 17 of 31, by MaxWar
Ha! I didn't even know this existed.
Reply 18 of 31, by Jolaes76
Until very recently.
Not yet "complete" but already with double the power of a Roland MPU. Sort of a Death Star against purist Rolanders 😀
Over 50 games are proven to work with it. There cannot be too much DOS game resistance left. Maybe some hide in remote corners of the Far East... Japanese, Taiwanese titles I mean 😀
