First post, by Jiri
Jiri
Offline
Some Guest wrote here about constant ticking noise when Gravis is used. (I cannot react there since the post is locked.) This ticking sound is probably similar to the noise I wrote about here. There is a file attached to that post with a samples from two games. I got annoying ticking sound with Gravis in more than two games, but I don´t remember the names. To the developers: Is this some bug you are aware of or has it rather something to do with the user settings? Thanks.
