First post, by leonardo
- Member
edit: This is one of those annoying threads that doesn't lead to a clear solution - the problem with Glide detection disappeared after I reinstalled Windows and I never found out what the root cause was.
One potential solution was posted over here.
Original post:
Two problems really...
#1: If 'Detect Glide' is checked during setup the game will display the 3Dfx logo and then crash like so:
#2: My Gravis BlackHawk Digital joystick seems to be completely randomly used in the game. Every now and then it works, every now and then it doesn't. All I can really do is keep rebooting the game in hopes that this time I have flight control.
The joystick problem I've had before, not being able to use 3Dfx high-res mode is a new problem for this system.
Any takers?
[Install Win95 like you were born in 1985!] on systems like this or this.
