First post, by Gabucino
Could someone send me DESCENTR.EXE from v1.4a? I have an 1.0 EXE which the 1.4a patch fails to recognize as correct.
Try an earlier patch, then patch to 1.4a
wrote:Try an earlier patch, then patch to 1.4a
1.0->1.4a and 1.4a -> 1.5 were the only ones I could find.
Are you using an original copy of Descent, or some dodgy "abandonware" copy?
wrote:Are you using an original copy of Descent, or some dodgy "abandonware" copy?
Yes, it's the original copy.
Oh ok then. 😀
Have you tried maybe re-downloading the patch, or reinstalling your copy of the game?
wrote:Oh ok then. 😀
Yes.
I don't suppose there may be a way to manually extract the exe from the patch installer, would there? Try using Universal Extractor http://legroom.net/software/uniextract on the patch installer file.
wrote:I don't suppose there may be a way to manually extract the exe from the patch installer, would there? Try using Universal Extractor http://legroom.net/software/uniextract on the patch installer file.
It's an incremental patch. So I need the EXE. Hence the topic.
Like I said, see if you can extract the exe from the patch installer.
There's also a 1.0 to 1.5 patch.
http://www.patches-scrolls.com/dl.php?file=dreg15.zip
Are you sure you have version 1.0 and not this problem?
wrote:Are you sure you have version 1.0 and not this problem?
Thanks for this little interesting tidbit, but I am quite sure, for I could read (yeah I'm _that_ good:) the version number printed by Descent. The problem has been fixed since then, by the way. Files available for posterity: http://gabucino.be/download.htm
I'm glad. Try to pm akula65, he might be interested in investigating the file further.
