Descent 1.4a request
First post, by Gabucino
Could someone send me DESCENTR.EXE from v1.4a? I have an 1.0 EXE which the 1.4a patch fails to recognize as correct.
Reply 1 of 13, by mr_bigmouth_502
Try an earlier patch, then patch to 1.4a
Reply 2 of 13, by Gabucino
1.0->1.4a and 1.4a -> 1.5 were the only ones I could find.
Reply 3 of 13, by mr_bigmouth_502
Are you using an original copy of Descent, or some dodgy "abandonware" copy?
Reply 4 of 13, by Gabucino
Yes, it's the original copy.
Reply 5 of 13, by mr_bigmouth_502
Oh ok then. 😀
Have you tried maybe re-downloading the patch, or reinstalling your copy of the game?
Reply 6 of 13, by Gabucino
Oh ok then. 😀
Yes.
Reply 7 of 13, by mr_bigmouth_502
I don't suppose there may be a way to manually extract the exe from the patch installer, would there? Try using Universal Extractor http://legroom.net/software/uniextract on the patch installer file.
Reply 8 of 13, by Gabucino
It's an incremental patch. So I need the EXE. Hence the topic.
Reply 9 of 13, by mr_bigmouth_502
Like I said, see if you can extract the exe from the patch installer.
Reply 11 of 13, by SKARDAVNELNATE
Are you sure you have version 1.0 and not this problem?
Reply 12 of 13, by Gabucino
Thanks for this little interesting tidbit, but I am quite sure, for I could read (yeah I'm _that_ good:) the version number printed by Descent. The problem has been fixed since then, by the way. Files available for posterity: http://gabucino.be/download.htm
Reply 13 of 13, by SKARDAVNELNATE
I'm glad. Try to pm akula65, he might be interested in investigating the file further.
