First post, by john00001
Does anyone know how to set the PC beeper to work on DOSBox ? Currently beeper sounds are going through the soundcard. I think it its in dosbox.conf ?
Also, is there any way to set the turbo off, like a turbo button (i.e. at 4.77 mhz) ? I can use ALT-f11 but I don't know what speed old CGA games are supposed to be.
Reply 1 of 8, by mr_bigmouth_502
DosBox is intended to be a multiplatform program, and as such they won't be adding PC speaker output, at least not in any official builds.
Also, due to the way instructions are emulated on DosBox (with each instruction taking exactly 1 clock cycle), it's impossible to really replicate the speed of any particular CPU.
If you're looking for something that better approximates the speed of a PC XT, I highly recommend this program. http://www.picofactory.com/free/software/pc-xt-emulator/ It's not well known, but I used to use it to play old CGA games many years back. All you need is a 360k DOS boot image, and some way of injecting your game files into floppy images http://www.winimage.com/ and you're set. 😉
Reply 2 of 8, by john00001
Okay, thanks.
Reply 3 of 8, by rdflg
On the subject of the PC speaker, I attached a small microphone to the top of the PC speaker and fed the cable from it out of the PC and having soldered a 3.5mm jack plug on the end, plugged it into the MIC socket of my Sound Blaster sound card. This works EXTREMELY well but...only if Windows is running. Soooooo does anyone know how to adjust the MIC input level if running under MSDOS?
rdflg
Reply 4 of 8, by leileilol
That's really old (2006) and has strange design decisions... a Tseng ET4000 bios required for a XT?!
Reply 5 of 8, by Jorpho
The same way you adjust the regular volume: by using your soundcard's DOS-based mixer program.
Reply 6 of 8, by eL_PuSHeR
[Thread moved to DOSBox General Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 7 of 8, by rdflg
Thanks for the comments. Incidentally, using the mixer program that comes with Sound Blaster cards, namely SBMIXER.EXE, in DOS is no good, Jorpho, as it only allows one to adjust Synth, CD and Wave volumes i.e. only outputs but no inputs...
Reply 8 of 8, by mr_bigmouth_502
It's only required for VGA mode. 😉
