Privateer JEMM
First post, by xfirenovax
Ok first off, I'm an idiot. So feel free to make fun of me.
I recently learned of DOSbox and am giving it a try. Mainly for one game Privateer. I install privateer and try to play it but always get this error
No Privateer CD Found
Jemm unloaded
and thats it. I'm currently running under Windows XP
any help?
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
Which command did you use to mount the CD with (in DOSBox)?
_________________
Reply 2 of 4, by xfirenovax
mount d e:\ -t cdrom
MOUNT C C:\
Those were the only two mounts.
If you actually have privateer working it be better just to tell me how to do it, like step by step.
I installed Privateer by using the run command install
Then use DOSbox c:
cd\priv
priv
then get the Privateer CD not Found
JEMM unloaded
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
Sorry, I do not have Privateer.
Try adding '-ioctl' to the mount command (it enables some low-level emulation). If that does not work, try adding '-label XXXXX', where XXXXX is the actual CD-ROM label.
Btw. this is in the FAQ section of the ReadMe:
Q: The game/application can't find its CD-ROM. A: Be sure to mount the CD-ROM with -t cdrom switch. Also try adding the cor- […]
rect label (-label LABEL). To enable more low-level cdrom support add
the following switch to mount: -usecd #, where # is the number of your
CD-ROM drive reported by mount -cd. If you run Win32 you can specify -ioctl
or -aspi. Look at the description elsewhere in this document for their
meaning.
_________________
Reply 4 of 4, by xfirenovax
Thankyou a bunch...I got it to work
I owe you one (thought I doubt i'll check back here often)
