mac hpv card question
First post, by soviet conscript
I'm looking at grabbing a 8100 hpv card for my 6110cd. Problem is I'm not really sure what I'm looking for as nothing comes up in eBay under Macintosh hpv. Is this a controller card or is it an actual video card with a monitor output. Basicly I want it for the VRAM and better colors/resolutions. If it is a video card does that mean my audio vision monitor will not benefit from the vram. I know there's an av card that adds vram as well but its less then the hpv card and is slower from what IV read.
Reply 1 of 8, by sliderider
This is what you're looking for
http://www.ebay.com/itm/Apple-Macintosh-PDS-V … =item1e830a9f02
Take note that for use in 6100 machines, you'll need an angle adapter if you don't already have one.
Reply 2 of 8, by soviet conscript
Will the system still take advantage of the VRAM on that card if I use the built in port to display to my audio vision monitor?
Reply 3 of 8, by sliderider
The memory on the card isn't shared with the rest of the system, if that's what you're asking.
Reply 4 of 8, by soviet conscript
Yhea it was. So to utilize the VRAM I need to have the monitor hooked up the the card hosting the VRAM. The site I was reading wasn't clear on that and implied once installed the VRAM was shared. Which means I'll need an adaptor for my audio vision monitor.
Reply 5 of 8, by NJRoadfan
The HDI-45 port was only found on that monitor and the PM6100/7100/8100's built in video was the only thing that had the matching port. Honestly its easier to just use a VGA monitor at this point. Apple did make an adapter that allowed one to connect the AudioVision 14 to a standard Mac DB-15 port (split out the video,audio, and ADB functions of the HDI-45 jack), but its difficult to find.
Reply 6 of 8, by Jorpho
Have you seen anything to indicate that the AudioVision is capable of resolutions greater than 640x480?
Reply 7 of 8, by soviet conscript
ah, your right. If I want to take advantage of a better res I suppose I'll need a diffrent monitor. Shame, I like the look and convinence of the audiovison.
Reply 8 of 8, by NJRoadfan
The Audiovision looks nice with a 6100 because its proportioned for the short pizza box case.
