First post, by theuserbl
Hi!
Is it possible, to make the border color of MSDOS visible?
GW-Basic / QBasic have had three color values:
COLOR 7, 1, 2
The first is the foreground, the second the background and the third the border.
Games like "Crystal Caves" also makes use of the border color. As default the border color is red. If you have collected all crystals, then it changed to green.
The border is around the pixeld area. So running today on current computers MS-DOS, the border can't be seen, because the TFT-monitores don't show it. Only old tube monitors showing the border with its color.
So, is there an option in DOSBox, to enable the border? So that there will be a frame around all, with the border color?
Or is it planned, that it will be implemented in the future?
Greatings
theuserbl
