VOGONS Driver Library
Reply 180 of 1645, by SquallStrife
vetz wrote:
I've uploaded those drivers from subhuman in my compilation. Just waiting for the upload to get accepted by you 😀
The new version is called v1.2. You can delete the previous entries.
What do you mean "accepted by me"?
Reply 181 of 1645, by Stiletto
Just uploaded:
dgVoodoo 1.50 Beta3 source, open-sourced under LGPL. Thanks again to Dege.
http://www.vogonsdrivers.com/getfile.php?fileid=496
I will probably remove/move it when The Wrapper Collection Project goes online.
do the Fandango!" - Queen
Stiletto
Reply 183 of 1645, by jwt27
Just found this CD:
What do you guys think, is it worth uploading?
edit: attached README.TXT, CATALOG.TXT, and a list of all files/dirs on the disc.
Reply 184 of 1645, by SquallStrife
Yeah, looks like a neat collection!
And from the looks of it, the POD and "SABREACE" (??) are shareware versions.
Chuck it on, I reckon.
Reply 185 of 1645, by jwt27
Found 135 bad sectors while ripping... I'll let it read the bad sectors overnight, see if they can be recovered.
The disc contains four games, all shareware: POD, Tomb Raider 1 and 2, and Sabre Ace (looks like a Glide/D3D2 flight sim?).
Reply 186 of 1645, by SquallStrife
There's a steady flow is shit-stains trying to attack the site using a Joomla exploit. Most of these hits are using some kiddies tool showing a User-agent of "BOT/0.1 (BOT for JCE)".
Of course this has been unsuccessful, as Joomla is not used on the site in any way/shape/form.
I made some tweaks to the .htaccess file, and added a line to the HTTP 403 error message screen, just in case they're paying attention. 😀
Reply 187 of 1645, by jwt27
Aww shit, almost forgot about that CD. I'm trying to put together a list of all drivers/versions on this disc right now. There seems to be a lot more stuff on here than mentioned in the readme. Including even more shareware games I've never heard of.
Reply 188 of 1645, by jwt27
Finally finished uploading. Here's the links:
https://app.box.com/s/oerylgcwl816iwtm1uj6
https://app.box.com/s/e9edb4qae7i6lu19apc9
https://app.box.com/s/b2z41oxjw26y00ki7931
https://app.box.com/s/vfa6em2r7ox7e75ewb20
https://app.box.com/s/ndzm2j1ajxcel01gl6a1
https://app.box.com/s/rxtiha31s2dihc2s9k44
I used a multipart 7z because my broadband connection is... not so broadband. And a bit unstable at times. You can unzip it and upload the single 7z file inside.
Reply 190 of 1645, by d1stortion
I have some 3dfx related stuff which I wouldn't mind sharing, will you create an account for me?
Also, as a suggestion for improving the site, maybe each upload should have a picture to prevent confusion, since there can be different revisions etc
Reply 191 of 1645, by SquallStrife
Yeah man, I can make you an account no worries.
There is a facility for uploads to have an accompanying picture, it's just that most of them don't. 😜
Reply 192 of 1645, by d1stortion
Thanks for that! OK, here is the deal: One of the things I have here is that Diamond Multimedia Super CD which is already uploaded (file name DSCD_2_98.ISO), but mine happens to span 2 CDs which are marked 1.2/98 and 2.2/97, respectively. Shall I upload either or both of them?
Reply 193 of 1645, by d1stortion
...huh? 28 megs MAX? 😳 how come there are 400+ MB uploads on the site then?
Reply 195 of 1645, by d1stortion
Wasn't aware of this being called "Trolling for Beginners"...
Anyway, stuff's all up now 😀
Reply 196 of 1645, by SquallStrife
Use the FTP upload function for >30MB files. 😀
Reply 197 of 1645, by beepee
Been lurking here for a long time and finally posting. I spent several hours getting my old lunchbox EISA 486 networked (in DOS, using MS client and what turned out to be a very obscure ISA nic) last night and had help from the driver library! So I went through my old floppy collection and found a few I didn't see in the list:
Gravis Joystick Utilities
Logitech Mouseware 8
Also, this technically isn't a driver so not sure if it should be added, but it is a blast of nostalgia for anyone who had a packard bell 386 (like I did!) 😀
Packard Bell DOS VGA Menu with Tutorial
Thanks everyone!
Reply 198 of 1645, by Skyscraper
This thread seems more fitting than the one I posted this in so I moved my post here.
I found a good source for rare and not so rare audio drivers.
Parhaps it would be good to create a mirror of this FTP or just download all drivers for future use in case it disapeers.
http://download.solodrivers.com/gestor_downloads/tsonido/
The above link is for audio drives but there are other directories for other types of hardware in the parent directory.
I noticed that this FTP has been linked once before here on Vogons but that link only points to a specific file.
There was no information that the FTP actually hosts ALOT of drivers.
Reply 199 of 1645, by rodimus80
I found the drivers on a floppy for a older InterAct ProPad 6 Serial gamepad. I also have the drivers for Gallant SC-4000. Are these worth it to be uploaded?
