Reply 3120 of 57469, by keropi
SC-8820 received today and dissected:
I like it so far, been testing it with tilakat's GM fixed games (dn3d and dooms mainly) to hear the differences between sc-55/88/88pro , the cool button on the front changes maps without resetting the unit 😀
Reply 3121 of 57469, by Skyscraper
170 SEK ~ 17 Euro, locally.
Reply 3122 of 57469, by karateka
Skyscraper wrote:
http://i.cubeupload.com/eOELNr.jpg […]
Nice catch!
A word of caution about the A7M266-D.
I used to have one as well and these are known to have been suffering from bad capacitors due to the Capacitor Plague (a very interesting story on its own 😊)... http://en.wikipedia.org/wiki/Capacitor_plague
Have a look and if you see a bulged capacitor that looks like this do not plug the motherboard in power. You might damage the board and other connected components. From the picture you posted it looks fine but its worth having a closer look.
Reply 3123 of 57469, by mockingbird
I only see two or three capacitors on the A7M266-D that need replacing. Two Teapos to the left of the Northbridge, and possibly one more at the top of the board behind the I/O panel, specifically the one right behind the two USB ports. The rest of the caps on the board are Rubycons and Fujitsus. The Teapos have different vents than anything else (three converging diagonal lines with three dots in-between each line.
Reply 3124 of 57469, by PeterLI
Reply 3125 of 57469, by Mau1wurf1977
Is there a rule to this? My impression is that you should go after the big ones (in size and capacity). The little ones don't seem to "pop" that often so to speak 😀
My YouTube channel
Reply 3126 of 57469, by Old Thrashbarg
I wouldn't call it a rule, per se, but I'd say that's a fair assessment. I generally don't bother with the ones under 470uf, unless I have some particular reason to think they may be bad. The smaller ones like that don't tend to be quite so critical, nor are they usually under a lot of stress, so it's fairly uncommon for them to cause problems.
Note that I'm only speaking of motherboards and such, though. Power supplies are a different matter... depending on the circuit design, the small caps in those can cause all kinds of havoc (up to and including runaway voltages that fry everything in the system).
Reply 3127 of 57469, by sliderider
I picked up a pair of boxed Cirrus Logic VL Bus cards with manuals for about $11 each that had been preying on my mind for quite a while. You really don't see many VL bus cards for that price any more let alone ones that are complete in box. They're probably good to sit on until the time is right to resell them.
Reply 3128 of 57469, by Stojke
Have the same board and CPUs but no PSU. Aux out PSUs are a bitch to find.
Reply 3129 of 57469, by luckybob
I'm fairly certain the board will work fine with the normal and 12v power lead.
Reply 3130 of 57469, by Stojke
I tried, doesn't work.
But might be the memory when i think about it...
Reply 3131 of 57469, by luckybob
the chipset requires 266/333 ecc/reg ddr ram if memory requires. I use 4x of these: http://www.ebay.com/itm/390179786178
Reply 3132 of 57469, by Stojke
I tried 400MHz memory and thought the board will clock it down automatically.
I used to have 4x 1GB Corsair DDR memory which i sold with my Dell Optiplex GX280.
Reply 3133 of 57469, by luckybob
Well the ram I linked runs cas3 @ 400mhz. But it auto clocks down to cas2 for anything slower. You will not find better (stock) performance ram for ecc/reg. And honestly, I think 2gb is just right for a board limited to 4gb. you lose 1/2 a gig to pci devices, another half a gig to video card... 4x 512 fits nicely and is appealing to my OCPD.
Reply 3134 of 57469, by PeterLI
Reply 3135 of 57469, by F2bnp
Nice! If you don't mind me asking, how much did you pay for it?
Reply 3136 of 57469, by PeterLI
Reply 3137 of 57469, by dirkmirk
This is the $99 haul I got a while ago
I think one of the soundblasters has an asp chip? Nothing particulary special about the soundblasters except non-pnp and scsi, pretty sure these have the buggy mpu-401 unfortunately
That Digigram PCX20 I plan to run in a 386 rig to see if can get .MP2 audio files working as I think thats the supported format would be pretty cool alongside the mpeg decoder card!
I thought I hit paydirt with that Midiman winman but from what I can tell its useless for dos! I did'nt get the midiman portman in the same auction but thought I would put it here for discussion as I also think its useless for dos, whats the verdict toss or keep them?
The real treasure obviously is the Boxed Roland SC-7 and should alone have sold for at least $100!
The other kinda rare item is the 50pin 4X CD-BURNER, perfect for my AM5x86-160 VLB system or perhaps the cyrix 5x86-120? hmmm decisions decisions.
Part of the haul was a Roland keyboard that has no inbuilt speaker cant remember the model threw that out, about 7 or 8 programmes for creating midi music so I threw the lot out but kept about 25 floppy disks as these are getting harder to find.
My brother lives about 2.5 hours away so he picked it up and arrived for christmas so you can guess what my present was for chrissy 😀 ? The lot for free! Thanks Bro!
Reply 3138 of 57469, by easy_john
Can you say anything about "Digigram PCX 20"? What this card can? Compatibility?
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
