First post, by blakespot
- Member
So, I ma building this 486-class box. I just added in an Adaptec AHA-1542 ISA SCSI card. It's setup and working fine with my HD. I have a CD-ROM on the SCSI bus and want to get it setup in DOS (I have DOS 6.22 installed on the HD) so that I can use the CD-ROM drive to install Windows 95C.
Searching on MSCDEX, etc. it seems that I need the Adaptec EZ-SCSI software to get the needed DOS driver. (It is not a bundled package w/ the SCSI card). I am in a bit of a Catch 22 if this is the case; I have an ethernet card and and intended to use it under 95 to grab whatever software, but I can't install 95 without the CD-ROM drive. I have a 3.5" floppy on the DOS box, of course, but I have no other PC with a floppy drive in the house to write out a disk for sneaker net. (I have an Amiga 2000 and an Apple IIgs that are on my LAN that can prob. write out to a 720K DOS floppy, though).
Does DOS 6.22 contain what I need already, or do I actually need this EZ-SCSI package? Or is the driver file itself avail and downloadable?
Thanks. At a standstill, sadly.
bp
:: Visit the Byte Cellar, my vintage computer blog (since 2004).
:: See a panorama of my own Byte Cellar (a.k.a. basement computer room)...
:: twitter: @blakespot
