Mau1wurf1977 wrote:Are there motherboards that support W98se AND have integrated SATA ports?
Aopen Ak89 Max: http://www.anandtech.com/show/1303
AMD Athlon64 Socket 754 board with 8x AGP.
I own one (I was lucky to find one on ebay some time in 2012 for $45), nforce3-150 chipset, and SATA-150 onboard (although it's through the Silicon Image 3114 Chip), but the big reason I mention this board is Aopen has full Win98se drivers for all onboard features and functions on this board, including the onboard gigabit NIC, which can actually negotiate and obtain a gigabit connection, if your storage solution can manage to read/write fast enough to handle the speed.
I have tested a 80 GB Sata-150 hard drive and it will detect, and install windows on this, on this board and run just fine.
Edit: Also I've read this entire thread and I do not see a link to ATTO benchmark you're running in Win98se, could someone link me to a copy of that so I can see how one of my 98se machines is doing please?
